Thread: Help with sealing this pump connection
    I have tried several times to get a leak proof connection between the threaded joint on the pump and the suction side piping. I am using teflon tape, threaded the thing all the way and still got drips. Should i be using something other than teflon tape? Any tips?
    [attachment=0:utqyhiua]2013-05-259509.55.34 (2).jpg[/attachment:utqyhiua]
    Walnut Creek, CA. 18k gallon Pebble Sheen + 1.5k gallon IG spa, 1.5hp whisperflo main pump, Pentair clean and clear 420, Intellichlor IC20, Polaris 360 w/booster,Jandy lite 2 natural gas, plus solar with Heliomatic 5000 controller and 3/4 hp booster
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    Re: Help with sealing this pump connection
    Try some thread sealant
    Jeff
    Thanks Jeff, can you recommend a brand?
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    Really any brand that's for PVC will be fine. Lowes or Home Depot will have it.
    Jeff
    30,431
    +1 what Jeff suggested.
    Thanks for the advice, that did the trick.
