Thread: Sand pump with saltwater pump
    Does anyone know if the Krystal clear sand pump can be used with the Krystal clear saltwater pump? I know there is an all in one saltwater/sand pump. I have a saltwater pump from my last pool and I'm wanting to use it with my new sand pump. Thanks in advance!
    16' x 37' Rectangular Plaster Pool w/ autocover 21,000 gallons.
    Re: Sand pump with saltwater pump
    Welcome to TFP!
    If you have an Intex pump with a sand filter you want to use a Krystal Clear Saltwater System, ie the version sold without a pump.
    It is possible to convert the pump with SWG into just a SWG so you can use it with the sand pump, but it involves destroying the pump portion and some minor improvisation with connectors.
    I have the Krystal clear sws model cs8110 and Krystal clear sand filter pump model sf15110. Will they work together? I'm sorry I misspoke and said it was a saltwater pump. It is not a pump. If they will work do I hook up the salter water system after the sand pump?
    Thanks so much!
    Yes, that combination is fine. You connect the salt system after the pump/filter.
    God bless you! Lol thank you so much. I almost went and bought a whole new system.
