Thread: Filter sprays like a geyser when set to filter
    May 2013
    Nashville
    2
    Hello, all! Long-time reader, first post. I've attached a pic of my problem.
    I opened the pool last week and stupidly walked away after starting the pump. When I came back about 14 hours later, I was met by the sight of water jetting out from between the multi-port valve and the filter body.
    All works fine on waste/rinse/backwash/circulate. But when set to filter, it immediately acts like a very expensive sprinkler system!
    Any ides/tips/dire warnings before I start taking things apart and randomly looking for clues?
    Thanks in advance for any help.
    Joe
    [attachment=0:3mefz1cx]photo.JPG[/attachment:3mefz1cx]
    In-ground vinyl || 16X36 || Pentair WhisperFLo 2 speed pump || Hayward top-mount sand filter
    3 returns, one skimmer, double drain
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,380
    Re: Filter sprays like a geyser when set to filter
    Have you pulled the top of the filter off lately? You may have pinched a gasket or o-ring. Pull the multi-port valve off and check the condition of the spider gasket, any o-rings or gaskets between the multiport and filter body and inspect the rim of the filter body as well. Check the rim for cracks. Make sure and gaskets and o-rings are seated correctly, are not worn, and that the screws tighten firmly.
    Love TFP? Become a
    TFP Supporter!
    30,419
    Inspect that leaking connection to the multiport carefully. The source looks to me like it is coming from that connection.
    May 2013
    Nashville
    2
    I took it apart and the gaskets and o-ring looked fine, so I stuck a hose in the sand and rinsed it all out and then stirred it with a stick. Put it all back together, crossed my fingers and set it to filter.....and it worked. Ha! I win this round, Mr. Pool.
    Thanks for the input, TFPers.
    Joe
