Thread: Water coming out from underneath filter
    I posted last night about my current pool equipment. You can read the details here.
    need-help-with-1966-pool-is-what-i-currently-have-bad-news-t60559.html
    However, this morning I went out to see how to implement some of Jason's ideas when I came across a much bigger problem. The first thing I noticed was the pool was about 8 inches lower than yesterday afternoon. Obviously a leak - but was unsure where. Walked over to the filter and water was pouring out from underneath. I took a quick video to show the extent of the leak. Pic of the filter attached as well.
    http://www.youtube.com/watch?v=zsUT1MRbCvA&f
    I then turned everything off and disconnected the filter. Flipped it on it's side and expected to see some sort of crack. Nothing. I can't see or feel anything major but I realize it might be a hairline. Kinda hard to pinpoint without it running - and no way to see the bottom while it's running.
    I took the plug out and the o-ring was broken. Ah! I thought I had solved it. Ran up and bought a new plug and o-ring, came home and put it all back together. Leak is the same if not worse now.
    Has anyone ever run across this problem before? Am I missing something obvious? Is it even something that can be fixed or should I start looking into buying a new filter?
    Re: Water coming out from underneath filter
    Put the valve into recirculate until I figure out a more permanent solution.
    If anyone has any ideas - I can always take more pictures or videos as needed.
    Thanks.
    22,553
    If it is the vessel body leaking it'll have to be replaced. The first thing to do is to make sure it's not a fitting leaking and running down under the filter.
    I can't think of where it would be coming out from - none of the fittings are leaking. Must be cracked underneath. Looks like I'll be shopping for new equipment.
