Thread: whats wrong
    whats wrong
    fc 6
    cc 6
    ph 7.6
    ta 140
    cya 180
    ch 100
    have shocked pool for twe days water still slight green tint and cloudy what am i doing wrong??
    10,000 gal ag intex krystal clear pump 633t and cartage filter
    Jun 2012
    Howell, NJ
    977
    Re: whats wrong
    First, the CYA. It is way too high. How did you get that number? Here is what I would do.
    *1) Order the proper test kit (link in my signature).
    2) While waiting, read pool school numerous times, especially the shocking topic.
    *3) Test your water, and post up results.
    4) Drain as much water as needed to get CYA down to 50. That would be 72% of water. You should probably do this in cycles, because 70% is a lot to drain
    5) Start the shock process based on a CYA of 50 (link in my signature).
    Just a side note, with a CYA of 180 shock level is 34 and you should never let FC drop below 14.
    Skip #s 1 and 3 if you already have a TF-100 or K-2006.
    John
    7 year old ~13,500 gal 24' AGP with 1.5 hp Proline pump, 150 sqft Pleatco cartridge, filled with well water with pH of about 4.5.
    Wanda the Whale pool vacuum, home made heater, Taylor K-2006
    Cloudy Pool? 1) Order test kit. 2) Follow SLAM
    New to TFPC? Read Pool School a few times, then post questions. PoolMath will help with chemical additions.
    BoDarville's Avatar
    Jun 2012
    DFW, Texas
    3,841
    Re: whats wrong
    Quote Originally Posted by JohnN
    Bigchief, if you do not have either of these kits, what are you using to test with?
