Results 1 to 12 of 12
Thread: muriatic "not recommended for fiberglass, vinyl-liner..."
    Aug 2011
    Northville, Mi
    312
    Why does Leslie's say that their muriatic acid is "Not recommended for fiberglass, vinyl-liner, painted, or acrylic pools."?
    I haven't seen anything like that on here anywhere. And is their muriatic different than the stuff you buy at HD or Lowe's?
    15,400 gal, 16x32 vinyl rectangle (sport dig), Intelliflo VS, 240 sqft cartridge filter, Intellichlor IC40, Mastertemp 250, Dolphin supreme M4 cleaning, Pentair EasyTouch4, Tested regularly and accurately with supplies from tftestkits
    30,415
    Re: muriatic "not recommended for fiberglass, vinyl-liner...
    Can you post that link? That is so silly. muriatic is muriatic.
    Rockland County, NY
    52
    Muriatic acid in its typical concentration could cause problems with a vinyl liner IF not applied correctly. Whereas you could typically just pour it into a concrete (gunite) pool directly, you wouldn't want to apply it that way if your pool is constructed with some form of plastic material. When I apply liquid acid to my vinyl pool, I dilute it in a five gallon bucket at a ratio of 40:1 (water to acid) and slowly pour the mixture over the return jet at the deep end of the pool. Years ago when I knew little in the way of pool maintenance, it didn't take long to ruin the vinyl liner with the improper application of acids to the pool. Perhaps there are other reasons Leslie's has posted the warning, but from my experience, this would seem to be the most logical.
    22,000 gallon ig vinyl solar heated (panels and cover) zeolite filtrate
    That doesn't make any sense to me. Pouring full strength muriatic acid directly onto any kind of pool surface will damage the surface, while adding it as we recommend (pour slowly in front of a return jet with the pump running) is fine with any kind of surface. It really doesn't matter what kind of pool you have.
    30,415
    Applied in front of a return, pump running, it is perfectly safe to apply muriatic directly from the container. That is the method suggested by this forum and it is applicable to ANY pool.
    Aug 2011
    Northville, Mi
    312
    Here's the link: http://www.lesliespool.com/Home/Pool...ers/14013.html
    I know I had previously received that advice here (pour in front of jet while pump running) for CYA, wasn't completely sure if that applied for muriatic as well. I kinda figured it was Leslie's avoiding liability for people who aren't careful but wanted to check.
    I may or may not dilute it for my own purposes, so it's good to now what my options are. Need to lower TA from 110 down to the recommended target range (60-80) and the pH just a shade as well.
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    I've never diluted it. Just poured slowly in front of the return flow.
    Isaac-1's Avatar
    SW Louisiana
    6,711
    It is important to remember the slow part here, also that muriatic acid is MUCH heavier than water and will sink to the bottom of the pool if not well mixed by the return.
    Aug 2011
    Northville, Mi
    312
    I poured in one gallon veeerrryyy slowly over the jet with the pump running at a high setting. What I noticed is that, even after shaking up the bottle (a few times), little flakes ended up floating around. I could see quite a few that ended up on the floor and even a little "pile" of them in one spot. As soon as I finished, I took my skimmer and stuck it in the water and mixed up that area and then I threw the dolphin in to further stir up the water.
    Hopefully that was enough to avoid any future issues, but figured I'd post it here in case anyone else experienced this and didn't notice it.
    Mar 2007
    San Rafael, CA USA
    12,082
    In general, when adding a concentrated chemical that is heavier than water such as Muriatic Acid, chlorinating liquid or bleach, I would add it slowly over a return flow (preferably in the deep end if it has a floor drain) and after you are done, then lightly brush the side and bottom in the area where you added the chemical. That will ensure thorough mixing and prevent any pooling.
    30,415
    What did you pour in?? I have never seen muriatic acid produce flakes nor should you EVER have any reason to shake the bottle!!
    Aug 2011
    Northville, Mi
    312
    Oops! I was talking about the conditioner! Sorry! Haven't added any muriatic yet. Whew!
