Results 1 to 7 of 7
Thread: High TA reading
    Jun 2012
    Hudson Ohio
    47
    High TA reading
    Here are my current test results
    FC 7
    PH 7.6
    TA 230
    CH 230
    CYA 40
    My understanding is that TA should be around 70 to 90.Pool calculator does not suggest anything to reduce my high CH. Will the high CH cause any issues to my equipment.
    18 x 54 Sharkline Matrix pool. 7800 gallons.
    Pentair Optiflo 1 1/2 HP 2 speed pump
    Pentair Clean and Clear 150 Sq Ft cartridge filter
    Hayward H100ID Heater. Purchased all from Poolsupplyworld. TF-100 TEST KIT
    dafuzz's Avatar
    Apr 2013
    North Florida
    66
    Re: High TA reading
    Here are the instructions on lowering TA. http://www.troublefreepool.com/pool-...l%20alkalinity
    There's a "Pool School" link at the top right of every page on TFP where most of the important info is cataloged.
    Good luck!
    ~31k gallon 18x36 IG, Vinyl LoopLoc Sahara, Hayward C-750 75sq' Cartridge filter, Pentair Intelliflow VS3050, SGS Breeze760 SWG, Homemade Aerators, SmartPool Nitro 52 Wall Climber, TFT100 XL, Borates, and a partridge in a pear tree :)
    dafuzz's Avatar
    Apr 2013
    North Florida
    66
    Re: High TA reading
    A whole sentence disappeared. The only way to lower CH is to drain and refill, provided that the water you put in is lower in CH. There are those who manage just fine with high CH by keeping their water balanced.
    30,431
    Re: High TA reading
    Slow down a bit, guys. The CH test result is 230....there is no reason to adjust it.
    Jun 2012
    Hudson Ohio
    47
    Re: High TA reading
    I just read my initial post. I meant to say should I lower my TA
    30,431
    Re: High TA reading
    High TA can, but not always, cause your pH to rise.
    If your pH stays pretty stable, leave TA alone. If your pH is constantly rising, reduce TA according to the article in Pool School.
    Jun 2012
    Hudson Ohio
    47
    Re: High TA reading
    Thanks Duraleigh. Now if it would just warm up here in Ohio. Woke up to 34 degrees.
