surferbum:
Like you, I tend to be a simplifier. I usually go with the simplest solution that will solve the problem or meet the need. Having said that, certain features are best added when the pool is built such as a spa, water features, and specifying 2" plumbing to name some. So if any of these are on your list, I would add them when the pool is built. A word about water features (e.g., waterfalls, fountains, etc.): The more of these you add, the more pumping power and flexibility you will need. If you were to install several such features, you may have to step up to a variable-speed pump to get the flexibility you need to turn them on/off. This will add cost to your pool build. Generally, one water feature such as a spillover spa or fountain is sufficient to provide a certain level of ambiance many pool owners desire while providing you with the ability to aerate your water which helps manage pH and TA. Plus managing one water feature can be done using a lower HP 2-speed pump instead of a VS pump.
It seems like you are on the fence regarding adding a SWG. Unless you travel a lot, I would leave that out for now. That is something that is easily added later. As the others have said, I would ditch the ozone generator.
Another item that many PB seem to push is the in-floor cleaning system. I would definitely avoid that. It adds cost to the initial build and provides that many more opportunities for malfunctions. It also usually requires a second pump. Plus, IMHO, it breaks up the uniformity of your pool's finish with all those pop-up heads. Would suggest either a pressure-type pool vac (e.g., Polaris) or robot type (e.g., Dolphin). Both of these alternatives are a far less invasive way to keep your pool clean.
As for filters, the king of simplicity is the sand filter. About the only maintenance a sand filter needs, aside from backwashing, is opening the filter lid once a year, breaking up any sand clumps that may have formed, and performing a deep cleaning as described in
this post. The sand should last the life of the filter.
