Thread: No CYA
    No CYA
    I finally opened up our 18x33 AGP 2 days ago. I did a test with tf100 and had no chlorine and no cya. I put in a gallon of 8 % bleach and 4.4 lbs of stablizer. I retested tonight after running pump for 24 hours. Have FC of .5 and still no cya. I added another gallon of 8% bleach. Should I add in more stablizer or give it a little longer?
    My pH was at a 7.5 but after adding the stablizer it is down to 7.2. Should I worry about this right now?
    Do I need to put any algaecide in it as it is very green?
    This is my first time as a TFP user!
    24' round above ground pool. 15,200 gallons. Hayward Pro Series sand filter and Hayward 1hp Powerflow Matrix pump. Upstate New York
    Re: No CYA
    After you add solid stabilizer you should give it a week to fully dissolve and show up on the test before adding more.
    Your PH is fine for now.
    If the pool is green and cloudy/murky then you need to shock the pool. See the instructions on shocking in Pool School.
    Algaecide is not particularly useful for fighting an algae bloom, it is much better at preventing one in the first place. Once algae gets going you need to shock.
    Re: No CYA
    So if i use the pool calculator im aiming for a FC level of 10 then? That
    Amounts to two jugs of my bleach. Does that sound right for the
    Shock? How long do i need to keep this FC level until algae is oxidized? Thx
    Re: No CYA
    Please read the article in Pool School on how to shock your pool.
