Thread: Solar valve keeps turning
    May 2013
    Las Vegas, NV
    3
    Dear forum, I have a Goldline Gl-235 solar controller. Recently when turning it on from the panel, the valve no longer stops in the open position after 90 degrees, but keeps on spinning. I am able to open it manually to the proper position using the toggle switch, but does anyone know if just means replacing the valve?
    Regards, Oms
    IG, fiberglass, 4000g, 1.5HP Jacuzzi pump and filter
    Goldline GL-235 Solar controller with roof panels
    Jandy 2440 Valve actuator
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Re: Solar valve keeps turning
    What modell valve and actuator are you using?
    May 2013
    Las Vegas, NV
    3
    Thank you, it appears to be a GL-24V valve and a Jandy Valve Actuator 801424.
    Regards, Oms
    At worst you may need to replace the actuator, but the valve should be fine. The stop position is set using cams inside the actuator. From your description, it seems likely that either the cam or the switch that the cam interacts with have broken, though they might simply have come out of position.
    May 2013
    Las Vegas, NV
    3
    Thank you!
    Regards, Oms
