Results 1 to 9 of 9
Thread: Bleach vs SWG
    Bleach vs SWG
    New pool owner.
    Chlorine is low @ .5
    Should I raise chlorine by increasing % on SWG or add bleach??
    Thanks
    Shawn
    13,900gal 24'x52" Backyard Leisure Heritage AGP
    20ml All Swirl Flat Liner
    Pentair 1.5hp Pump and 150# Sand Filter System
    Smart Step Ladder w/Smart Light
    TF100 test kit, BBB Baby!
    Re: Bleach vs SWG
    If you think you need to shock (which is likely) you should add chlorine manually. When shocking the pool you want the FC level to come up quickly, which is not what a SWG is designed to do.
    You haven't told us much, so I have no idea if you need to shock or not. If you just opened and the water is clear the surface clean then there probably isn't any reason to shock. But if the water is cloudy/murky green then you clearly need to shock. We can give you much more detailed help if you give us more information, especially the rest of your chemical levels and what the water looks like.
    Jun 2012
    Howell, NJ
    977
    Re: Bleach vs SWG
    How long has the chlorine been this low? What is CC? How does the water look? If it has been low for too long, you may need to shock. That is best done with bleach. I don't have a SWG, so take my advice with a grain of salt (pardon the pun). I would get the chlorine up to suggested range with bleach, and then adjust SWG percentage as needed.
    John
    7 year old ~13,500 gal 24' AGP with 1.5 hp Proline pump, 150 sqft Pleatco cartridge, filled with well water with pH of about 4.5.
    Wanda the Whale pool vacuum, home made heater, Taylor K-2006
    Cloudy Pool? 1) Order test kit. 2) Follow SLAM
    New to TFPC? Read Pool School a few times, then post questions. PoolMath will help with chemical additions.
    Re: Bleach vs SWG
    Sorry should have added the water is crystal clear looks perfect but chlorine is low.
    Still learning what % I should set my SWG at? PB said to leave it at 15% but I think that is too low. Have gradually raised to 25% and I feel that is probably too low as well. Running pump 8 hrs per day.
    UN1017's Avatar
    May 2012
    Sacramento, CA
    288
    Re: Bleach vs SWG
    Based on your previous posts:
    14000 gal
    Jandy Aquapure
    CYA 50
    What model is your Aquapure?
    15'x30' IG - Roman-style - 14K - Pebble Fina Classico
    Filter: Jandy CL460 Pump: Jandy Stealth SHPF1.5 SWG: Jandy AquaPure 1400 Cleaner: Jandy RayVac Test Kit: TF-100 w/SpeedStir
    Chlorine/CYA Chart----Extended Test Kit Directions----SLAM
    Re: Bleach vs SWG
    1400
    Jun 2012
    Howell, NJ
    977
    Re: Bleach vs SWG
    If your FC is at .5, 25% is clearly too low. I don't know what a good setting would be though. You will just have to keep experimenting.
    John
    UN1017's Avatar
    May 2012
    Sacramento, CA
    288
    Re: Bleach vs SWG
    This is what I would do:
    1. Add bleach to reach 4 ppm chlorine
    2. Throttle your SWG up to 45%
    3. Bump your CYA up to 70
    4. Adjust your SWG to maintain levels as indicated in the chlorine/CYA chart
    Your (our) SWG is capable of producing up to 1.25 lbs. of chlorine gas in a 24 hr. period. At 15% for 8 hours you were only making 1 oz. You need almost 2 oz. just to raise your pool 1 ppm. If you lose 2 ppm per day to sunlight.....well you know. Of course these are all approximations but at least it's a place to start.
    Re: Bleach vs SWG
    Thanks for the advice.
