Results 1 to 7 of 7
Thread: Can I leave the winter cover on in MN until it gets warmer?
    Jun 2012
    Blaine, MN
    106
    We still have our winter cover on. We siphoned most of the water off the cover. Yesterday I hooked up the pipes to the pump/filter so I could bring the water level back up. Slipped my hand under the cover (there's a gap because we couldn't get the wire any tighter). Here are my results with 2-3 more inches of water to add yet:
    7.5 ph
    15 fc
    .5 cc
    14.5 tc
    140 ta
    70-80 cya
    56 temp (dang that's cold)
    I know the temp was closer to 70 before I started adding water. Is it feasible/advisable to keep the cover on until the water gets closer to 70? I would keep an eye on the chemicals and start running the pump/filter today or tomorrow if you think this is a good idea. I am so not looking forward to our weather forecast of "rain/maybe we'll hit 75" one day next week.
    blondemarcello
    18x33 16,700 gallon AG
    Sand, TFP Test, Gas heater
    Minnesota
    Re: Can I leave the winter cover on in MN until it gets warm
    It is best if you can open the pool before the water gets to 60 degrees. You can put it off longer than that, but the odds that algae will get started go up quickly as the water warms above 60.
    Jun 2012
    Blaine, MN
    106
    Do the odds for algae increase because I wouldn't be able to brush thus not able to "stimulate" the water?
    blondemarcello
    Minnesota
    May 2013
    Long Island NY
    419
    I still have my cover on in Ny. But my pump is hooked up and I run it every day for 4 hrs.
    I also put a little chlorine in and I keep a close eye on it everyday.
    19,000 gal - Vinyl IG - Sand filter -1.5hp. - Taylor k 2006 - Loop Loc cover
    Smykowski's Avatar
    Sep 2011
    3,065
    Quote Originally Posted by samt
    This is exactly what I'm doing as well. Cover will come off next week.
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    I'm doing the same thing also. I check FC level every other day and run pump for 4 hrs. I'll be taking off as soon as all the seed pods are off the maple tree. I don't need a pool full of
    those things.
    Water temp was 72 on the bottom when I checked the other day.
    Jeff
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Quote Originally Posted by blondemarcello
    I don't think that really matters. Basically, algae growth rate increases with temperature. Most likely over the winter your FC level went to 0, so once algae starts to grow, there is nothing stopping it.
    If you can get some chlorine in there and circulating like mentioned above, I would.
    By the way after fixing the leaks in my solar panels today, our water got up to ~64F this afternoon.
