Thread: The Liquidator Tank presents an ideal test environment
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    To check how liners tolerate high chlorine. Unfortunately, in spite of tearing up the house, I can't find my cutout liner pieces. I was planning on cutting a small section of pattern in half, and placing one half just below the water surface and keeping the other as a control. I doubt you'd ever find a handier source of very high level chlorine for a test like that.
    Mantua, NJ
    80
    That's how I cleaned the plastic treads on the ladder. Dipped them in so the bleach covered half, pull them out, wipe, rinse and reverse for the other side.
    Joe
    21k IG vinyl, 300 lb. sand filter, 1hp pump, Polaris 280 cleaner, 3/4hp booster pump, 240sq ft Fafco solar, Liquidator
