Thread: What is the Life Expectancy of a Salt Cell?
    Guest
    Hi friends,
    I posted this question at the end of an old thread, but decided to ask it on its own:
    The SC-60 cell on my Total Control system is just reaching the 10,000 amp hour mark as we start year 5, and I am wondering what the expected life is.
    In an earlier thread, Jason mentioned that the cell should average about 60,000 hours - which shocked me only because I thought the average is about 10,000! (Get it? SHOCKED me? A little pool humor - very little, I know... )
    Can anyone confirm that the life is more like 60,000 hours - that this was not a typo? That would be great news, and very helpful as far as planning when I need to have a replacement on hand.
    I did have an error message recently that said "Cell Inspect Due - SELECT to clear". I figured this is a built in pre-programmed 10,000 mile checkup that Aquacal built in - not really indicative of a problem. But it made me start thinking that I'd better be prepared with a new cell when it happens!
    Thanks!
    Elise Levine
    Upstate NY
    mas985's Avatar
    Pleasanton, CA
    11,737
    Re: What is the Life Expectancy of a Salt Cell?
    Units are important. I think Jason was suggesting perhaps 60000 amp-hours not 60000 hours. If the cell on average uses 7 amps, this would be about 8600 hours of run time and depending on the settings, this could be a good number of years. For example, in my case, my cell is about 7 years old and I run it about 4 hours of SWG on time in the summer and about 2 hours in the winter or a 3 hour per day annual average. So that is about 7665 hours so far. But different cell designs will most likely have different amp-hour life ratings so you would need to know the rating for your particular cell design.
    Mark
    60,000 is the expected AutoPilot cell lifetime in amp/hours, the same units that are reported in the diagnostic menu. This is not the same as hours, as mas985 explained. Remember, there is always some variation from unit to unit. I expect that your unit is large relative to the size of your pool, and thus should last quite a bit longer than the usual 3 to 5 years.
    "Cell Inspect Due - SELECT to clear" is just a reminder to do routine servicing, not an indication of any problem.
    pinguy's Avatar
    May 2015
    Pennsylvania
    516
    Quote Originally Posted by JasonLion View Post
    Mine just threw this message for the first time. What routine servicing do you do?
    Helpful Links: Pool Chemistry 101 - Recommended Levels - Recommended Chemicals - FC/CYA Chart - SLAM Instructions - Pool Math
    Test Kits:
    TF-100 - Taylor K2006 - SpeedStir Upgrade - Taylor K-1766 Salt Test
    My Pool:
    28k IG built May 2015 - Autopilot SWG - Pentair VS Pump/DE Filter/Heat Pump
    Ft Lauderdale, Florida
    1,455
    Just visually inspect the cell for calcium scale build up. Otherwise, press and hold the SELECT button until it clears (about 8 seconds)
    Sean Assam - Sean@teamhorner.com
    National Accounts and Commercial Products Manager
    AquaCal Heat Pumps www.aquacal.com
    AutoPilot Salt Chlorine Generators www.autopilot.com
