Thread: table and stools in pool
    hi everyone and anyone, we are in the process of designing an inground pool, we would really like to add in a table and some stools. does anyone have these in your pool and how does it interfere(probably spelled wrong) with your automatic cleaner.
    we are leaning toward a robotic cleaner. will probably be about an 18000 to 20000 gallon pool. help.
    Penny
    14,362 gal, AG, Krystal Clear Sand Filter Pump 16", SWG Model CS20110 Flow Rate 2,650 gal/hr, Installed 2012
    Aquabot Pura 4x
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    Re: table and stools in pool
    Your cleaner will probably not clean at all behind them. If you make the space large enough for the cleaner to get back there, it'll probably just get stuck. I think your best bet is to make sure the spaces are too small for the cleaner to get stuck in, and just sweep behind them every now and then.
    thanks for the input i agree
    Penny
    Aquabot Pura 4x
