Results 1 to 12 of 12
Thread: Removing debris at opening
    Apr 2013
    Long Island, NY
    29
    I didn't see any posts related to my topic so just have a quick question. Had a service open our pool yesterday. We have a loop loc mesh safety cover so some debris has collected at the bottom while it was closed. They added what looked like a gallon of liquid chlorine and he recommended waiting until the water was clear and we could see to the bottom...then power vacuuming 1/3 of the pool debris (leaves and algea on bottom etc.), then shocking again and power vacuuming another 1/3, shocking one last time and removing the last 1/3 of debris. I'm new to pool openings so was wondering why one wouldn't power vac all of the debris out at once. Isn't the point to get the organic matter out of the water? The pool is pretty big 40k gallon L-shape. And my last important question...should we be following the "Pool School" instructions for shocking the water now or wait until all the debris is cleaned out? Thanks in advance for your help.
    40K, IG vinyl, Hayward Pro Series sand filter (S244T), Hayward chlorine feeder (CL-200), Aquabot Turbo T2 robot
    May 2012
    NW PA, halfway between Pittsburgh and Erie in the PA snowbelt
    159
    Re: Removing debris at opening
    The only thing I can think of is this....
    If you remove all the debris, then there are less organics in the pool to clean, thus less chemicals it will take to clean, thus less money the pool store will make.
    Read Pool School here and the shock process and do that instead of what the store told you to do. I don't have personal experience with it myself, but I've read enough others' experiences here to believe what I learn here on the forum.
    Mike
    22' round Intex UltraFrame pool, Intex 633T 2500gph paper cartridge filter/pump
    with broken Intex SWG, using bleach this year
    TF-100 test kit
    harleysilo's Avatar
    Mar 2012
    North Georgia
    1,924
    Perhaps during the process of trying to vacuum 1/3 of the debris you'll stir up so much you won't be able to see the rest. Is your water clear?
    18'x43' Sport Pool
    19,000 Gallons Vinyl Liner 3'-3.5'-4'
    SWCG and D.E. Filter
    Test Kits - Pool Calculator - Chlorine/CYA Chart - Pool School
    Secret Weapon for Pool Chemistry Testing
    Apr 2013
    Long Island, NY
    29
    You can see to the bottom in the shallow end but not the deep end yet. I couldn't find anything on pool school about removing debris in conjunction with shocking and balancing the chemicals. In short, should I remove all the debris and then shock or begin shocking while I am power vacuuming?
    @ Mike above...a pool service company opened the pool...not a retail chain trying to sell us chemicals. One would assume he is being honest about the procedure but perhaps he was setting us up for failure so we wouldn't be able to clear up the pool ourselves and would need to call him back to get it up and swimable. I know...these guys are all salesmen. He did try and switch us to a salt water system and I knew better than to fall for it thanks to all the experts on this forum.
    harleysilo's Avatar
    Mar 2012
    North Georgia
    1,924
    I would scoop/vacuum until i couldn't tell what i was doing, then start following the POOL SCHOOL instructions for shocking your pool. Anytime i could see debris that could be vacuumed, i would vacuum or scoop them out. Do you have the means to test Chlorine levels above 5 PPM? Do you know what your CYA level is?
    18'x43' Sport Pool
    Apr 2013
    Long Island, NY
    29
    I will post water results shortly
    May 2013
    Deep East Texas
    79
    One word of caution about vacuuming what you can't see; I did just that about a year ago and got a few short sticks stuck in my suction lines. After a few more tugs on the vacuum I had a solid clog in the lines. After hours of work getting it out I still believe there may be a small stick stuck in there waiting for me to vacuum up a good pile of debris and clog it up all over again. My lesson learned: stick with netting out as much as possible and save
    the vacuum for the really small stuff that you see.
    In ground 25,000 gallon - vinyl liner - Sand filter - residential pool
    Also maintain two commercial 190,000 gallon competitive indoor bromine facilities -9x Sand filters
    Apr 2013
    Long Island, NY
    29
    Ok, all the debris has been removed from the pool. Should I brush the walls before, during, or after starting the shocking process?
    Jul 2007
    Chicago, IL
    87
    I'd get the chlorine in the water and then start brushing. Brush often and check your FC level every hour to start with, adding chlorine when necessary to bring it back to shock level.
    28K, 20' x 40' IG - Vinyl Liner, Hayward DE Filter, 1.5HP Pump, 250K Hayward BTU Heater, Aquabot Breeze 4WD robotic cleaner
    Apr 2013
    Long Island, NY
    29
    My TF100 has not arrived yet so I went to the pool store for testing. I added a gallon of Clorox this morning and vacuumed to waste and then brushed the pool.
    FAC 0
    TAC 0
    CH 90
    CYA 0
    TA 90
    PH 7.3
    TDS 200
    Pho 500
    The water was pretty clear (prior to brushing). So what are my next steps? Should I add or do anything while I am waiting for the test kit? They said it could take 5 days to arrive. Thanks!
    I'll let the experts guide you, but my first thought would be to get your CYA up...without it you won't be able to hold chlorine.
    ~25k gallon, IG,Vinyl, Sta-Rite System3 Cartridge Filter, Installed June 2010
    Jun 2012
    Butler, PA
    336
    I brush and sweep/vacuum mine as much as possible when I am shocking, which I am doing so currently. I began the shock process (per pool school instruction) when I had debris in the pool, but I was and continue to remove it as I continue the shock process. I did not begin actively shocking until my cya was introduced to the water. The cya is necessary as it allows the chlorine to remain in the water and do it's job. Without it, your chlorine will be instantly consumed. If you had cya/stabilizer in your pool prior you still should have some in the pool. I could not get mine to register until the water warmed some (I put mine in the house to warm prior to testing). If you had cya in prior and have not changed out the water, I have read it can convert to ammonia. I don't know the science behind it (it can be read on the boards) but if your cya has converted to ammonia ~ you will consume chlorine at a more rapid rate than if it was just attacking organics/algae. Additionally if you dose for CYA ~ it will take a week to register if you go with the granular which you hang from a sock at one of your returns.
    I work outside of the home so I move some water in the morning before heading to the office ~ I also check my shock level and adjust it for the day (I add a bit extra to compensate for loss while I am gone). When I get home from work, I am back at it ~ I always brush it a few times in the evening & I sweep/vac when I am able. Weekends I hit it full tilt.
    My pump/filter are running constantly (this keeps the water moving as well)
    Last week I spilled reagents from my kit so I had to limp along a bit, not testing as frequently as I like. Which I did monitor my shock levels & I kept the water in as much motion as possible, even though I wasn't able to test like I wanted/needed to.
    I would let an expert advise you on your current cya level, but in the interim I would do what you are able to do to keep the water in motion: pump/filter running constantly & brush your pool as much as you are able. To shock properly you are going to need cya in that water. and it is difficult to maintain absolute levels without proper testing, but you can keep the chlorine levels up until your test arrives. Just don't go crazy with the chlorine until someone advises you what you should do about your cya.
    AGP: 27' x 52" : 17,500 gallon
    300 lb. Sand Filter (75 gpm) / 1.5 hp pump
    Full Sun ~ All Day
