Thread: No Ground Cover
    No Ground Cover
    Was hoping someone can answer this question for me. If I do the pavers under the legs, and the insulation foam boards on top, do I still need the tarp ground cover over top the insulation?
    20,000 gallons
    In Ground Vinyl, Sand Filter
    Pool is older than 5 years
    Orlando, FL
    690
    Re: No Ground Cover
    I did and I've read where others have also put the ground cover on top of the foam. Now, I feel roots moving and I don't care. I say, the more the better.
    Sharkline Reprieve 15x52 (3/14). Still using Intex 2650 Sand Filter with Hayward Power-Flo Matrix 3/4 HP pump (6/15). Solar Cover cut into strips for easy removal, (2) 2*10 Space Saver solar panels. Swim Jet HD Robot (by Aquabot) (3/15). Chlorine Liquidator (4 gal). 4 person hot tub. Hard pipe is the way to go for improved flow! Retired Lil Shark (3/15). Starite Max E Therm 333k BTU Propane Heater w/ 24 gal tank (7/15).
    Re: No Ground Cover
    My question is more, do I have to put a tarp down? My original ground cover was thrown away and I would like to not buy a new one if I don't have to.
    20,000 gallons
