Is it ok to use Calcium hypochlorite for rising CH?
Sure. Pool Calculator will tell you how much each gram of cal hypo will add if you change the units (upper right) and enter all your numbers. It's down where it says Effects of Adding Chemicals. You won't be able to add it all at once or the FC will be too high.
