Results 1 to 12 of 12
Thread: Pool been running a week, here are results????
    May 2013
    Deville, LA
    6
    Hello all, I am a total noob to the pool world but have been reading a bit but still a little (lot) confused. anyways here is my story filled the pool up about a week ago, city water got my paper filter pump going for 24hours and then added 140lbs of pool salt, set my swg for 4 hours a day as the book said to do and after a week this is my test results
    fc 0
    cc 0
    ph 8.4
    ta 180
    ch 250
    cya 100
    the water seems to have a greenish tint to but I have a clear swg and the water going threw it looks crystal clear. Any suggestions? Oh I am using aquachem test strips I know they are not as good as a kit but it is what I have at the moment, I will get a kit ASAP. Thanks
    6500 Gallon AG vinyl pool, 1500 gph intex paper filter, swg, 2nd year to have the pool.
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Re: Pool been running a week, here are results????
    Welcome to tfp, ididthatwell
    Yes the test strips are likely wrong...especially regarding cya. Do you believe your cya is really high...i.e. have you used a lot of trichlor pucks, dichlor, or added stabilizer in the past?
    If yes, then it is likely your cya is high and you may want to consider draining and refilling to start from 0. Is your pool an intex type?
    Quote Originally Posted by ididthatwell
    Is it cloudy in the pool or is the water just clear but tinted? If just clear but tinted, then it sounds like metals in the water (probably iron...though this is less common when using municipal water) and may disappear once you lower your ph. If you are not going to drain now, then use poolcalculator.com to calculate how much Muriatic Acid to lower from 8.4 down to 7.4 and add it at the water return to the pool while the pump is running. Then with pump still running test again in an hour and repeat process until your ph is down ~ 7.4.
    I would recommend getting one of the recommended test kits. But if you do decide to do a drain/refill then you might be able to get by with the HTH kit mentioned in the link for now.
    May 2013
    Deville, LA
    6
    Yeah, I am not sure those test strips are correct. I am going to take a sample to a pool store and get better reading. Do you think draining the pool and starting over will help? I mean I did not add any chemicals so won't it just be the same way? all I did was run the pump and add salt? yes my pool is a intex. Its not cloudy at all very clear just tinted.
    30,432
    If you didn't add any CYA to your pool, it does not occur naturally so you have 0 CYA.
    Throw the strips as far as your strength will allow....better, give them to someone you really don't like.
    The pool store results probably aren't much better. Get yourself a GOOD test kit and learn how to manage your own water.
    Meanwhile, you have NO FC in your pool. How did you chlorinate last year?
    May 2013
    Deville, LA
    6
    We did it manually but never got it right and gave up quick, did not use but one or 2 times at the begining. I am going to get some stabilizer tomorrow and some Liquid chlorine and see what I can do. I have some ph minus and slowing getting the ph down, going to test in the morning and work on getting that down and then will add the stabilizer and bleach. I ordered a good kit online today but in the mean time I went to walmart and got the 6 way test kit they sell there.
    30,432
    Because you only filled a week ago with city water, I question your pH is that high (Have you thrown out those strips, yet?)
    The 6-way you just bought seems to do pretty good on pH so check what it says before you start putting in acid or anything else to lower pH.
    May 2013
    Deville, LA
    6
    ok so I think I am starting to get somewhere, I added stabilizer lastnight and will not be able to get a correct reading for a week from my understanding but here is what I have as of now.
    fc 5
    ph 7.5
    ta 180
    ch 300
    cya na
    30,432
    How much?
    May 2013
    Deville, LA
    6
    the pool calculator said 35oz but I only did 27oz to be safe
    30,432
    Okay, so you can count on enough CYA to be around 30 ppm and you are ready to start the shock process, right?
    How does your water look and how are you testing now?
    May 2013
    Deville, LA
    6
    yes I think I am ready to shock, water looks pretty clear but I do have a few water bugs in I guess Boatman? This what I am testing now with the walmart hth 6 way test. Not really sure about how to shock yet, need to do more reading unless you can walk me threw it?
    fc 5
    ph 7.5
    ta 180
    ch 300
    cya na
    30,432
    read "How to Shock Your Pool" up in Pool School
