Thread: Autopilot install location
    May 2013
    Boca Raton, FL USA
    21
    Hello!
    I'm considering an Autopilot SWG. I am considering installing the manifold right after the heater output (indicated in the red box on the picture).
    Is this location ok? Are there any issues with mounting it sideways like that?
    Thx!
    35x17 Inground concrete/plaster. 19,500 Gallons.
    Hayward H250 LP heater, Hayward 1.5HP pump, Hayward cartridge filter.
    Useful Stuff: Test Kit | CYA/Chlorine Levels | Pool Calculator
    Re: Autopilot install location
    That is not a good location. The AutoPilot manifold is designed to be installed on a horizontal pipe, with the loop pointed up. Installing it there would allow hydrogen gas to accumulate in the heater, potentially leading to an explosion.
    May 2013
    Boca Raton, FL USA
    21
    Well that wouldn't be very good and it would probably upset my wife.
    What if I came out of the heater straight into the manifold (with the loop pointed up) ? My fear there is the static pressure increase created by the 3 90degree elbows that would be needed to complete the circuit.
