Results 1 to 7 of 7
Thread: pump cord is melted
    pump cord is melted
    Bad news......my doughboy pump stopped working- and I looked and noticed that the outlet plug is black and melted on one prong.....I am not sure what to do at this point? Just buy a new pump? I don't even know if the pump will work since I can't plug it in. I was adding bleach to my pool tonight when I got home from work and noticed it wasn't running-
    I need to add bleach but have no way to circulate it- and I have had my solar cover on for three days...what should I do?
    21 ft Round Dough Boy
    3/4 horsepower Dough Boy PowerPak II pump
    Vinyl Liner
    baqua goo convert
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Re: pump cord is melted
    burned plug is often a sign of corrosion in the outlet causing over heating, you may only need to replace the outlet and the plug on the end of the cord if your lucky.
    p.s. you could use a boat paddle to stir your water after adding chlorine, when my pool pump was out a couple of months ago I used an engine powered "trash" pump to stir my pool water, I just happened to have it around
    Do you think my pool store would have a temporary pump I could use while they try to fix the old pump?
    I will have to call them tomorrow morning?
    Vinyl Liner
    baqua goo convert
    if I have to buy a new pump do I just go with the same 3/4 hp like my old one...is the piping dimensions the same for all brands?
    Vinyl Liner
    baqua goo convert
    Isaac-1's Avatar
    SW Louisiana
    6,711
    If I were just looking for a pump to circulate water and get by with for a couple of days with a pool your size I would look at Harbor freight or even one of the cheap Intex pumps from Wal-Mart, etc. that could be plugged into a heavy duty extension cord (use a GFCI OUTLET)
    Like this
    http://www.harborfreight.com/14-horsepo ... 68486.html
    or this
    http://www.harborfreight.com/34-horsepo ... 69297.html
    Note these are not UL listed for pool use, so no one should be in the water while they are running.
    Happy to report that after cutting the cord and adding a new plug and outlet...everything is up and running
    Vinyl Liner
    baqua goo convert
    Vette's Avatar
    Jul 2012
    Ohio
    404
    Did it have a plastic cover over the outlet that closes over the cord while it's plugged in?
    11,700 gallon 21' round 54" deep all-resin AGP - June 2012
    Waterway 1HP 2-speed pump / 100 sq ft cartridge filter
    Hayward 150,000btu Natural Gas heater
    I use and recommend the TF-100 for testing
