Thread: sticky pump motor
    rlefig's Avatar
    Apr 2013
    Reading, MA
    201
    sticky pump motor
    Hi I am going to someday be moving into a short sale house (once the sellers bank gives the word) with pool that needs a new filter and pump motor. The motor at first only hummed and did not start and then blew a breaker. I separated the motor from the housing and removed the diffuser (oooh the technical terms). I then spun the impeller and it barely moved, but once it did it, which only took another second or so of coaxing, it moved well. I plugged it in again and it started fine. Since then I have plugged it in more than 5 times over a couple without issue every time it started fine.
    So my question is should I lube it with anything? Anything else I should do? The rubber rings look good.
    Here is a picture of motor specs.
    Thanks
    Rob
    1971 Gunite 31x16 IG Kidney shape pool approx 18000 Gallons
    EcoFinish Blue Lagoon
    Sta-rite System3 S7M120 Cartridge Filter
    A.O. Smith 3/4 HP motor, starite pump
    TF100 test kit
    mas985's Avatar
    Pleasanton, CA
    11,737
    Re: sticky pump motor
    The bearings are probably going bad and will need to be replaced or the motor replaced.
    Mark
    rlefig's Avatar
    Apr 2013
    Reading, MA
    201
    There is no noise like car wheel bearings. I guess I will just budget for replacement one day. I will run more tests and if it starts every time hope for the best for now. The motor had not been started in awhile.
    Thanks
    TF100 test kit
