Results 1 to 9 of 9
Thread: SWG vs EPA-approved alternatives
    May 2013
    South Florida
    17
    I'm learning a lot on this forum. Thank you all for sharing!
    Right now I'm leaning toward converting to a SWG pool. It's appealing to have a closed system rather than buying and lugging jugs of chlorine and other chemicals.
    However, I saw mention in this thread that there are some EPA-approved alternative sanitizers: http://www.troublefreepool.com/alter...uth-t3025.html
    My question is this: Are things like SoftSwim, Revacil, and Baqua chlorine-free?
    I've learned on this forum that the products such as Ecosmarte and Technopure seem to be garbage and don't actually work.
    Would something like SoftSwim actually work and be chlorine-free and chemical-free?
    I'm really trying to find out if it's possible to go chlorine-free and still maintain a safe pool. If not, I'll go with a SWG system.
    38,342
    Re: SWG vs EPA-approved alternatives
    No they are not "chemical free" they use DIFFERENT chemicals that are more expensive, that honestly do not work as well as chlorine.
    May 2013
    South Florida
    17
    Thanks for the fast response jblizzle.
    I'm learning there's a lot of junk science out there. I have my family's safety in mind but don't want to be duped.
    An alternative such as SoftSwim is presented as being safer and healthier than chlorine. Is that not true? What chemicals are used? It's hard to sort through their "all is perfect" approach on their websites.
    Is the prevailing opinion on this site that using chlorine is best, be it either as a normal chlorinated pool or a SWG system?
    May 2013
    South Florida
    17
    And is Go Chemless another junk company out there? http://gochemless.com
    Again, thanks to all of you. I defer to the experts on this issue. I'm really just trying to determine my options.
    38,342
    Quote Originally Posted by dc2sofla
    Basically, Yes.
    If you want to read about biguanide (often Bacquacil), check out the forum devoted to them:
    baquacil-use-and-conversion-f44.html
    It is full of people that have gotten sick of the very expensive chemicals and the persistently cloudy water who have now converted to chlorine.
    The third approved sanitizer (bromine) is ok too, but more useful in hot tub environments.
    38,342
    That is just another "mineral system" that puts metal in the water to try to prevent algae and kill stuff. Often chlorine is still required on a weekly basis. And the metal has the potential to stain the pool and turn hair green.
    We NEVER recommend putting metal into the water.
    30,426
    If you want a safe and sanitized pool without totally depleting your wallet, chlorine is by far the only real choice. This forum is completely centered around the use of chlorine and you will find no alternative that will measure up despite what you might read elsewhere.
    We will help you understand a chlorine pool (an SWG pool is a chlorine pool, too) but you will not find any advocates here of the alternative sanitizers....they don't measure up.
    May 2013
    South Florida
    17
    Holy ****. Bacquacil looks like it's hard as **** to maintain. I'm not looking for that at all.
    Thank you for preventing a disaster!
    Is Bacquacil even supposed to be safer? Do people just use it because of the bad press chlorine has gotten?
    38,342
    Likely that is how they are sold on trying it ... and then realize it is very expensive and a pain to maintain and switch back to good old chlorine.
