Thread: Connection between Agua Logic and Pentair heater
    May 2013
    San Dimas, Ca
    2
    Here is my problem. I had to replace the blower motor in my Pentair heater, in the process I broke the 2 low voltage wires that come from the Logic's main board (heater1) . So if some can show/tell me where to hook these two wires to my heater, I would be very appreciative.
    [attachment=0:72ptbh3j]heater relay.jpg[/attachment:72ptbh3j]
    AL
    mas985's Avatar
    Pleasanton, CA
    11,737
    Re: Connection between Agua Logic and Pentair heater
    Heater 1 relay connections. What you circled.
    Mark
    May 2013
    San Dimas, Ca
    2
    Quote Originally Posted by mas985
    Mark, that is a picture of the Aqua Logic board showing heater relay #1, the broken wires that need to be reinstalled, are in my Pentair heater.
    mas985's Avatar
    Pleasanton, CA
    11,737
    Ok so I am confused why you posted the Aqua Logic board. The Pentair control board should have a remote thermostat connection that the wires will connect to. It is also in the manual that you can download from here:
    http://www.pentairpool.com/pool-pro/man ... n.php?s=28
    Mark
