Thread: Stains With New Plaster
    I just had my pool plaster redone and I have some stains in different parts of my pool, I have tried brushing and it will not come off. My pool has been plastered for two weeks now. I have not ran my heat at all and just put my pool sweep in for the first time yesterday. My ph has been high since the plaster job around 8.0 I managed to get it down a bit. My calcium level is where it should be around 250. My cholrine level has been low, I just got it up to about a free cholrine level 3.00 yesterday. Not sure if my stains are organic or metal stains. Any help would be appreciated. I put a lime and a chorline tablet on two different stains and did not see either of them dis appear or lighten. Attached are some pics. Do you think these stains will go away on their own with chorline now in the pool cause I did not have any free chorline in the pool until now.[attachment=0:3v7ah2au]Pool 3.jpg[/attachment:3v7ah2au] Here is a picture of my steps
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,967
    Re: Stains With New Plaster
    If they are organic stains, chlorine will bleach them out.
    Before you do anything else, call the contractor. If it's only been two weeks, he ought to do something about it, even if it's nothing more than look at them and tell you they're organic.
    And if he doesn't do anything, then come back and search for stains. There are ways to differentiate between organic and metal stains, but you don't want to do anything that might affect the plaster until the plasterer has had his chance.
    Jul 2011
    Arizona & California
    803
    The stains may be simply dirt that has stuck on the surface.
    The best way to remove dirt stains is to use 100 grit wet&dry sandpaper and sand for a few seconds.
    Does the water need to be drained when applying the sand paper
    Richard320's Avatar
    Jan 2010
    18,967
    Quote Originally Posted by dave32cu
    Nope. Not if you get the wet or dry paper. It's actually designed for wet sanding at body shops. It will say on the back of the sheet if it's wet or dry.
