Results 1 to 15 of 15
Thread: Vacuum loosing suction
    bbecky75's Avatar
    Apr 2010
    Jasper, Alabama
    95
    I'm loosing suction when vacuuming. In the beginning, the vacuum works fine but then for some reason, suction is lost. I replaced my hose thinking it may have small holes but the problem is still there. Any suggestions or comments are appreciated
    30' Above Ground 18,000 gallons, Sand Filter, 1.5 hp Jacuzzi Pump
    22,549
    Re: Vacuum loosing suction
    It's most likely an air leak in the system somewhere. Since you replaced the vac hose I'd start looking at the other common places. Pump basket lid, Pump drain plug(s), Valves and fittings on the suction of the pump, etc..
    bbecky75's Avatar
    Apr 2010
    Jasper, Alabama
    95
    Thanks Bama but my pump is brand new
    22,549
    Even more reason to suspect a leak at it. Could be that a drain plug didn't get sealed well or the o-ring on the basket didn't get lubed. It also could be leaking at the adapter on the front of the pump or at a union if you have one.
    bbecky75's Avatar
    Apr 2010
    Jasper, Alabama
    95
    Ok, I'll check this things and see what happens but it will be saturday before I'll have a chance. One question, what is a union?
    22,549
    One of these.
    bbecky75's Avatar
    Apr 2010
    Jasper, Alabama
    95
    I do have one of these valves attached on the suction side of the pump.
    22,549
    I would run water over it and see if the bubbles go away or lessen while you're doing it. I'd start with lubing the pump basket o-ring and removing and resealing the drain plug(s) on the pump.
    bbecky75's Avatar
    Apr 2010
    Jasper, Alabama
    95
    Ok, thanks Bama!! I'll let you know what happens!!
    30,420
    bbecky75,
    Check your PM's
    bbecky75's Avatar
    Apr 2010
    Jasper, Alabama
    95
    Hello Bama, I think I have figured out the problem or should I say my boyfriend has figured out the problem.. The brissels on my old vacuum head were wore out and flat which caused the head to suction to the bottom and caused the pump to loose suction.. Silly me, new head fixed the problem!!
    Now I have a new problem of interest that I'll start a new post on..
    Thanks for your help!!!!
    May 2013
    Massachusetts
    148
    This may sound dumb, but make sure you're using the right end of the hose, I thought my hose was ad, went out and bought another. Same problem. Turns out the ends of the hose are different, one is for the skimmer hookup, the other is for the vacuum head. Reversing the will cause the hose to constantly duck in air.
    25,000 Gallons Inground, Gunite
    DE, Hayward Filter
    Loud pump
    Hayward navigator cleaner, leaf hose suction
    Jun 2012
    St Pete FL
    45
    Hey weird_tolkienish_f can you tell which end is the correct end to attach to skimmer and which to vac head...other than trying it one way and then switching if the first isn't working so well???
    5,000 gal Fiberglass paper cartridge filter, autochlorinator, BBB
    20,000 gal Pebble Tec paper cartridge filter, BBB
    15,000 gal Pebble Tec, DE filter, autochlorinator, BBB
    20,000 gal Pebble Tec, sand filter, BBB
    22,549
    On vacuum hoses where it matters which end you hook where it's because it has a swivel cuff. The swivel cuff is nice if your vacuum doesn't have a swivel joint, but it's not air or water tight and therefore needs to be attached to the vacuum so it stays under water all the time.
    Jun 2012
    St Pete FL
    45
    No swivel cuff here THANKS
