Results 1 to 12 of 12
Thread: filling pool from creek
    ok so i have a 15000 gal intex ultraframe with sandfilter and swg. we had to drain it over the winter and it's time to refill. since we live in the country and water is high here we fill it from our creek. I have filled if from the creek before and did get the water crystal clear after an investment in time and chemicals so i know it can be done. my question is, i found a post on the internet where someone filled their pool by pumping through their pool filter and the poster said they filled through the waste port of the filter and water filled the pool through the skimmer. so im wondering if this would be effective way of prefiltering the water and possibly save some time and money? any suggestions? i think the original poster was "duraleigh" any help much appreciated.
    30,424
    Re: filling pool from creek
    What size is your filter?
    38,318
    I don't think you would want to run the water backwards through the filter. Because then when you started it in regular filter mode you will blow all the crud out.
    harleysilo's Avatar
    Mar 2012
    North Georgia
    1,924
    Could you clean out your sand filter when done filling prior to turning it on for filtration?
    18'x43' Sport Pool
    19,000 Gallons Vinyl Liner 3'-3.5'-4'
    SWCG and D.E. Filter
    Test Kits - Pool Calculator - Chlorine/CYA Chart - Pool School
    Secret Weapon for Pool Chemistry Testing
    i have the 1650 gph intex sand filter. And i can clean the filter out after filling pool.
    Jan 2013
    Houston, TX
    1,079
    This thread is useless without pictures!
    I love the idea (seriously - this is awesome) especially since I drink from the creek when on long hiking trips / kayaking (see Katadyn Hiker Pro)
    TFP Moderator Chris V. ~16K Pool & Spa, 48NSF DE, IG Plaster Circa 2000, Intermatic PE653, Challenger pump with a 2 speed B2984, 20gal stenner chlorine injection, Houston, TX
    One cannot follow Islam and Christianity at the same time, nor can one follow pool store methods and TFP at the same time.
    Pool School -- Pool Math -- TF-Test Kit
    i can supply pictures of the filter i guess but not the actual setup i'm talking about because as of yet i haven't figured out how to do it.
    38,318
    All you should have to do is hook a hose to the front of the pump from the creek instead of from the skimmer. Assuming you are using the same pump.
    30,424
    jblizzle has you covered.
    Simply put the intake hose inside a box with a coarse screen so you don't suck up any rocks and run the intake hose from the creek to your pump. From the pump into the filter and then into the pool.
    Once pool is full, simply remove the intake hose from the creek and hook it up to the intake from the pool to the pump.
    Here is the huge caveat....I don't think your pump or your filter is capable of doing this job well. Your filter is small and will constantly clog and your pump probably doesn't have the "oomph" required to suck water out of the creek.
    It would be easy to do with a regular sand filter of say 200 lbs and a 3/4 hp standard pump but the intex equipment probably just isn't up to the task.
    It may work just fine but my bet is you will have some problems. Since you have done it once already, perhaps I am underestimating your equipment.
    Jan 2013
    Houston, TX
    1,079
    or rent a pump from home depot...
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,031
    I want to see pictures when this thing is hooked up and running!
    BoDarville's Avatar
    Jun 2012
    DFW, Texas
    3,841
    Somebody had to do it
