Thread: Digital filter pressure gauge
    Atlanta, GA (Dunwoody)
    59
    Does anyone know if a digital water pressure filter gauge is offered? Seems like an easy thing to do and would be nice to tie it into the iaqualink. Set pressure start point at cleaning and monitor it with alarms and backwash/cleaning thresholds on the software.
    Heinsite
    17500 pool/spa iAqualink Rev R, Pentair VSF, Pentair DE Filter, Waterfall, 3900 Polaris Cleaner, Goldline Saltwater Gen. w/t15, Rayvac 40,000 Gas heater, Taylor K-2006 Test Kit, Taylor Saltwater Test Kit
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Re: Digital filter pressure gauge
    You can use any standard water rated pressure gauge, most are male 1/4 inch NPT, the gauges sold to the pool market tend to be low quality and don't last but a couple of years I am sure you could spend hundreds if not thousands of dollars on digital gauges.
    A quick ebay search found this potential one with the right general PSI range, etc. http://www.ebay.com/itm/New-Ashcroft-0- ... 41725aaae8
    I assume it is water rated, but did not dig up the specs
    this could likely be done with cheaper pressure switches
    22,542
    What type signals does the aqualink handle? There are many pressure transducers on the market that would easily work but they are usually 4-20 mADC outputs.
    59
    I'm not sure on outputs, but i know you can run low voltage lights, sprinkler systems, etc on the iaqualink/jandy Rev. R board. There are a few extra two pin plug in slots.
    Heinsite
