Results 1 to 7 of 7
Thread: SpeedStir Question
    Mr. Blue's Avatar
    May 2013
    Spring, TX (Houston)
    95
    SpeedStir Question
    So my SpeedStir came in the mail yesterday.
    I have a couple of dumb questions:
    Do you use it for all tests that call for mixing, stirring, etc?
    Do you add in the first reagent while stirring, then add in the next while still stirring? Stop stirring in between?
    23K Gallon Freeform Tile Inground
    Hayward Super II 1.5 HP -- Pentair FNSP48 DE Filter @ 120 GPM
    Polaris 3900 Sport (with Booster Pump)
    Pool School Attendee -- The TF-100 Test Kit and the Pool Calculator keep my pool Trouble Free -- BBB Supporter
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,626
    Re: SpeedStir Question
    I bet a dollar to a doughnut Richard will be the first one to answer this question since he's the speedstir guru around these parts! I've listened to him rave on about it so much I just ordered one myself! Daddy needs his pool toys!
    Mr. Blue's Avatar
    May 2013
    95
    I used it for the first time yesterday. It's awesome, just want to make sure I am using it correctly.
    Definitely takes the hassle out of stirring.
    benavidescj's Avatar
    Apr 2010
    Fleming Island, FL
    431
    Yes, you can use it for all mixing tests. I put the water in, then turn it on to put in the testing reagents. It is a wonderful tool!
    Carlos
    Pool: 28,000 gallons IG; IC 40 SWG; Pentair 120 gpm cartridge filter; Marble finish; Pentair Wisperflow 1.5 hp; Polaris 360
    Spa: 350 gallon; Bromine
    How to shock your pool
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,037
    Quote Originally Posted by Mr. Blue
    I do. I just let it run. If it stops in the middle, I cycle it again. I bought extra stir bars, so I can do all the tests before I have to dump the tubes and do the dishes.
    Before you ask, check ebay. 5/16 *1 or 8mm * 25mm magnetic stir bar.
    Isaac-1's Avatar
    SW Louisiana
    6,711
    To follow up on Richards comment, it will also work the the other shapes of small stir bars (+, oval, etc)
    Mr. Blue's Avatar
    May 2013
    95
    Thanks for the replies, everyone.
    That is how I used the stirrer yesterday, just wanted to make sure I was using it correctly.
    I think I will pick up a few more bars as well. Maybe some other shapes too.
