Results 1 to 9 of 9
Thread: Getting rid of the weekly service. Would like some advice.
    May 2013
    Boca Raton, FL USA
    21
    Hello, everyone! First time, long time.
    My wife and I bought a house in South Florida last August. I commissioned the pool guy that handled the house we were renting prior to our purchase and he's been coming every Friday, since.
    When we moved in, the pool appeared to have a small pile of sand down by the main drain. Our pool guy vacuumed it up and didn't think anything of it. The next week, I noticed the same thing. This time, I examined the sandy substance and it appeared to be grit from the pool finish. (Diamond Brite, I assume). I mentioned this to the guy and he said 'hrm, maybe the calcium is off' and he sprinkled some stuff in the pool and that was that. Needless to say, my faith in the pool guy was starting to wane.
    I began reading here and purchased a Taylor K2006 test kit and it arrived yesterday. I checked my levels, and here's what I've got:
    FC 1.5
    CC 0
    CH 210
    pH 8.0
    TA 100
    CYA 80-100 (I thought it was 100, but when I really looked, I could still see the black dot faintly, so I'm not 100% sure on this one)
    Based on my reading here, I'd say my pH and CYA is WAY too high, and the FC is WAY too low. (caveat: we've had a LOT of rain this week and the pool guy comes on Friday -- test was Wed night) I'd guess that my CH has to be increased as well?
    I have played with the pool calculator and it's very intuitive and makes sense, but I'm not sure which level to adjust first.
    Needless to say, I think I'm getting rid of this guy at the end of the month. I've also been researching SWGs (as I'm a lazy guy) and they really seem like the way to go.
    Thoughts? Comments? Flames?
    Thanks in advance!
    35x17 Inground concrete/plaster. 19,500 Gallons.
    Hayward H250 LP heater, Hayward 1.5HP pump, Hayward cartridge filter.
    Useful Stuff: Test Kit | CYA/Chlorine Levels | Pool Calculator
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Re: Getting rid of the weekly service. Would like some advi
    Welcome to TFP.
    Add chlorine, calcium, then lower your pH.
    Low calcium hardness can damage your pool surface. The Pool School article Recommended Levels shows 250ppm as the minimum level.
    If you are considering a SWCG, you may be able to deal with your CYA where it is. Otherwise, you need to maintain a higher level of chlorine to account for the CYA. The Chlorine CYA Chart shows that you should be holding your chlorine around 12ppm, and never letting it get below 7ppm.
    Add enough acid to get your pH to 7.4 or 7.5, but don't get in in a hurry. Add a little and then check it again in a few hours to see where you are.
    May 2013
    Boca Raton, FL USA
    21
    Thanks for the reply, John. I do plan to go the SWG route, but I'm not sure that it'll be any time in the next few months. (Wife wants to finish furnishing this new place before I can buy toys for the pool)
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,581
    House toys ALWAYS trumps pool toys!
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Tell her the pool toys are to help you save money
    May 2013
    Boca Raton, FL USA
    21
    I think she'll be all for the SWG after picking up shelf-fulls of bleach when she goes to the grocery store..
    May 2013
    Boca Raton, FL USA
    21
    Pool guy came today and I let him know we would be discontinuing service at the end of the month.
    Watched him pour some bleach from a yellow carboy -- I estimated over a gallon, closer to 2. He also walked around the perimeter and sprinkled tri-chlor granules (he said it was tri-chlor anyway). I tested the water a couple hours after he left. FC is now 12ppm. If his program is basically 'raise FC to 12 every Friday', I'm amazed I've never had any algae, given the FC on Wed when I got my kit was 1.5
    I also re-did the CYA test, and I'd say that level is probably closer to 80 after reading the best way to do the test (sun, etc). I think I'm going to refrain from trying to drain/lower the CYA. It appears to be at the upper end of the spectrum for SWG which is in our future plans anyway. I am in the South Florida sun. After about 3pm the pool is in the shade, but it's in the sun all day until then. Is a CYA level of 80 actually ok for this part of the country?
    Also, would this work for raising my calcium? http://www.amazon.com/Morton-7877-Sa...lcium+chloride
    Thanks again for the advice!
    May 2013
    Boca Raton, FL USA
    21
    Does anyone know the answer to my question (posted above) ?
    Jun 2011
    Long Beach, CA
    2,781
    You can live with the 80 ppm of CYA, just make sure the FC stays above 6 ppm.
    The label said pure calcium chloride, so you should be good with that product.
