Thread: cya reagent numbers
    cya reagent numbers
    Im looking for a larger bottle of taylor cya r 0013 and i run across r 0013 /a /c /e /g .. can i use any or them with a letter after it or does it require that i use just the r0013 with no letters at the end?
    21X41, 30,000, ig, vinyl,48sf de, 1hp hayward super pump, 2" piping, 2 skimmers, 1 main inlet, 2 return, built in 1988, no enclosure, lots of trees around, direct sun. Thanks in advance to all who have answered my questions.
    benavidescj's Avatar
    Apr 2010
    Fleming Island, FL
    431
    Re: cya reagent numbers
    The letters after the R0013 are just sizes. You can use any of them. Here is a list:
    R-0013-A 0.75oz
    R-0013-C 2oz
    R-0013-E 16oz
    R-0013-F 32oz
    R-0013-G Gallon
    Carlos
    Pool: 28,000 gallons IG; IC 40 SWG; Pentair 120 gpm cartridge filter; Marble finish; Pentair Wisperflow 1.5 hp; Polaris 360
    Spa: 350 gallon; Bromine
    How to shock your pool
    Jun 2012
    Howell, NJ
    977
    I personally bought the 16 oz refill. Much better value for the money.
    John
    7 year old ~13,500 gal 24' AGP with 1.5 hp Proline pump, 150 sqft Pleatco cartridge, filled with well water with pH of about 4.5.
    Wanda the Whale pool vacuum, home made heater, Taylor K-2006
    Cloudy Pool? 1) Order test kit. 2) Follow SLAM
    New to TFPC? Read Pool School a few times, then post questions. PoolMath will help with chemical additions.
