Thread: Skimmer Weir Loud Banging
    Apr 2013
    Las Vegas, NV
    9
    Our swimming pool takes up 80%+ of our postage stamp backyard and is just a couple of feet from my bed. With the recent high winds, the skimmer door (I think I'm correct in calling this the weir?) is banging hard constantly and I'm not sleeping well at all. The sound is going right through the patio door. Is there any way to muffle the door safely, anything I can put on there? Is it safe to temporarily just prop it open or remove it or something during the night so I can sleep, until I can get a better solution?
    11k gal IG plaster pool w/spa (15x28 "freeform" oval), Blue Haven Pools cartridge smartfilter 550, Jandy VS FloPro 2.0hp pump, Laars Lite2 400k BTU gas heater, probably built 2004
    Dolphin Evolution X5 robotic cleaner, TF-100 Test Kit
    38,271
    Re: Skimmer Weir Loud Banging
    Try gluing some foam either on the door or the stop. Or try a self stick pad like for furniture on the stop (which should not get wet).
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,581
    If you don't run your pump at night, yes you can remove it until you get it figured out. My first thought is that your water level might be too low and causing it to bounce up and down a lot.
    Apr 2013
    Las Vegas, NV
    9
    Tried some furniture pads with some added Gorilla Glue on the stop, time will tell if that will hold and if that does the trick.
    My water level is not low, it's halfway up the tile (like maybe 1.5-2 inches from the top). If it were any higher the high winds might start blowing the water out of the pool
    We also got the pool cover working again, so that should help a lot as well. I think that's why the noise wasn't bothering me so much before. Like everything else in the pool and house, it looks like the cover wasn't ever maintained, lubed, or cleaned at all, so it's in dire need of TLC, and has only been working off and on. But saveable, I think, once we find time to work on it. I tell you, buying a house is quite an education in proper house maintenance, every time. We always try to inspect carefully, but if you don't really know what you're looking at, it's easy to miss just how bad some things are. And I think our inspector was a bit inept.
