Thread: New here, just getting started
    FC 3
    CC 2
    pH 8.4 +
    TA 260
    CH, CYA - need to get a better test kit.
    Have a basic 5 test kit by poolmaster.
    My water has always been pretty clear but I have some reddish brown staining around the inside bottom of my liner. Going to work this weekend on vacing, it'll clear alot up (its from last years pollen and some flock that the pool store told me to add I belive). Known I've had a problem the last year with high pH and TA but decided to start this year off right and try to get it under control. Question is How much muriatic acid do I add. From what I've read add muriatic acid to drop pH and in turn bring TA down. New to all this, is that the place to start or somewhere else.
    Thanks in advance.
    11K gal, AG,
    2650 Intex Sand Filter .95 Hp
    Intex Saltwater System
    1 yr, C Illinois
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Re: New here, just getting started
    Welcome to tfp, TGM
    Quote Originally Posted by TGM
    The place to start is:
    See: http://www.troublefreepool.com/pool-...kit_comparison Many of us like the tf-100, most bang for buck.
    After that (or maybe before), the first thing to do is lower ph (don't worry specifically about TA right now). It may be very high, so I would dose (using poolcalculator.com to calculate the dosing) to 7.4 with Muriatic Acid (MA) then retest after leaving the pump running for 1 hour. Then repeat dosing ph down to 7.4, followed by the hour of pump time...do this until your ph is ~7.4 after testing.
    After that, you/we need to know your cya level to know what level you FC should be at.
    If you haven't spent time there yet, pool school has a ton of info in it. The link is near the upper right of each page.
    30,419
    Hi, Tom,
    Welcome to the forum. +1 what linen said.
    BoDarville's Avatar
    Jun 2012
    DFW, Texas
    3,841
    TGM, welcome to TFP! ^ What they said.
    Thanks for your replies, ordered the tf-100. Will get rolling on it and sure I'll be back with question.
    Thanks again
    11K gal, AG,
    1 yr, C Illinois
