Results 1 to 19 of 19
Thread: First test result with TF-100. Advice???
    May 2013
    Gadsden, Alabama
    11
    Ok... I got my test kit in today.
    FC - 1 ppm
    CC - 1 ppm
    pH - less than 6.8
    TA - 30
    CYA - 90
    Pool was blue and cloudy... I couldn't see the bottom of the deep end.... started scooping with the leaf rake and wow.... probably got 50 lbs of leaves out. Now the water is green and swampy again. I kept scooping until I was getting no leaves... so most are out. I started draining the pool to lower the CYA... I plan on replacing about half the water. It's going to take a while b/c I had to start using a water hose to drain it. I was just pumping to waste... but the neighbors down the hill started to complain after I drained about 2500 gallons.
    I got on the pool calc and figured I need a lot of Baking soda, Borax, and of course good ol bleach. Any input or advice is definately appreciated... this is my first time!!
    Pool: Rectangle 26,700 Gallon, IG Vinyl.
    Pump: Century Centurion 1 HP
    Sand Filter
    30,408
    Re: First test result with TF-100. Advice???
    Welcome to the forum.
    I would start by getting your TA to around 60 or higher. Use the pool calculator for dosage amount and use baking soda.
    Next, retest your pH (it may have moved just a little) and then calculate and dose enough 20 Mule Team Borax to get your pH up around 7.4. Test an hour after you add this and redose if you are lower than 7.2
    Now read "How to Shock Your Pool" up in Pool School. Follow that article precisely (KEEP YOUR CHLORINE AT SHOCK VALUE) and your pool will begin to clear.
    Keep us informed of your progress.
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Sounds like time for a 3 am draining, maybe you can hide some of it when it rains
    Oh also welcome
    May 2013
    Gadsden, Alabama
    11
    Will do.. I'm finishing the drain/refill process first. Water level is to low to operate my pump right now.
    Sand Filter
    May 2013
    Gadsden, Alabama
    11
    Quote Originally Posted by Isaac-1
    Oh also welcome
    No doubt... lol. Thanks for the welcome. You guys are a wealth of pool knowledge. Can't believe I let the pool store beat me down last year.
    Sand Filter
    May 2013
    Gadsden, Alabama
    11
    How long should I wait before retesting after adding bleach?
    Sand Filter
    30,408
    If your pump is running, most chemistry is distributed in the pool in 30-60 minutes.
    May 2013
    Gadsden, Alabama
    11
    Ok.... Pump is running. Getting up to shock level now.
    Sand Filter
    May 2013
    Gadsden, Alabama
    11
    Test results at 4:00 pm
    FC: 22.5
    CC: 0
    TA: 70
    PH: 7.5
    CYA: 55 (Half way between 50 and 60)
    Water is green and cloudy. I can just make out the bottom of the shallow end. Pump is running good, I've had to backwash twice since I started the pump last night. Next steps?
    Sand Filter
    SkyKid's Avatar
    Apr 2013
    Upstate South Carolina
    137
    Keep your Free Chlorine at shock level and brush the pool at least once everyday
    When your water is crystal clear do the OCLT which Butterfly says
    You're done shocking when:
    It worked for me and now my wife and I are enjoying a clean crystal clear pool
    14600gal, In-Ground Fiberglass, Haywood s244t Sand Filter, Jandy Apure35 SWG,
    Haywood 2 speed 1hp pump, Haywood Pool Shark, TF-100 Test Kit http://tftestkits.net/
    Pool School http://www.troublefreepool.com/categ...etting_started
    Never been Pool Stored Thanks to TFP
    Smykowski's Avatar
    Sep 2011
    3,065
    Quote Originally Posted by SkyKid
    This advice is good. For the sake of importance, I'll say it again in another way....
    You're doing the shock process, so during that process, do not let FC get below shock level.
    May 2013
    Gadsden, Alabama
    11
    Brush and maintain shock level. Got ya.
    Sand Filter
    May 2013
    Gadsden, Alabama
    11
    This morning at 7:00 am
    FC: 11.5
    CC: 1.5
    PH: 7.2
    Added 2 1/2 Gallons of 8.25% this morning before work to get it back up to shock.
    We've got a childs B'Day party on June 15th... think it'll be ready by then?
    Sand Filter
    Vette's Avatar
    Jul 2012
    Ohio
    404
    If you keep it up, yes.
    11,700 gallon 21' round 54" deep all-resin AGP - June 2012
    Waterway 1HP 2-speed pump / 100 sq ft cartridge filter
    Hayward 150,000btu Natural Gas heater
    I use and recommend the TF-100 for testing
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Have so POP today, keep at it, hitting it hard and you'll be swimming a week before the kids party.
    May 2013
    Gadsden, Alabama
    11
    Ok results! Pool is crystal clear. Today's test:
    FC: 11
    CC:0
    TA: 90
    PH: 7.3
    CYA: 40
    I added a bit of baking soda to get the TA up a bit more. I'm going to see how the chlorine holds now... but it will be good. I've only been losing 2 - 4 ppm in 24 hours the last couple of days. What chlorine level would be safe enough for the kids to go for a swim.... they are salivating over the pool right now! lol
    Sand Filter
    30,408
    You can always swim safely up to the shock value so for your pool @ 40 CYA, that's 16 ppm.
    However, have you done an OCLT test to make sure you have no remaining organics? It'll still be ok to swim, but if you are in the middle of the shock process, it sorta' screws that up.
    May 2013
    Gadsden, Alabama
    11
    OCLT test... Should I add bleach back to the pool until 16 ppm. Measure after dark and again in the morning? or over a 24 hour period?
    Sand Filter
    Jan 2013
    Houston, TX
    1,079
    after dark and first thing in the AM. Its an overnight loss test. The goal is to see if there are anymore organics in the pool that the Chlorine is attacking. By testing overnight you eliminate sunlight from the equation.
    TFP Moderator Chris V. ~16K Pool & Spa, 48NSF DE, IG Plaster Circa 2000, Intermatic PE653, Challenger pump with a 2 speed B2984, 20gal stenner chlorine injection, Houston, TX
    One cannot follow Islam and Christianity at the same time, nor can one follow pool store methods and TFP at the same time.
    Pool School -- Pool Math -- TF-Test Kit
