Thread: Pool has no weir
    Modawg2k's Avatar
    May 2013
    Phoenix, AZ
    334
    Pool has no weir
    My pool never had a skimmer weir installed. I had someone tell me that some pools these days are built without them. Is that true or does every skimmer need a weir?
    ~15k gallons, 3'-5'-4' Figure 8 Shape In Ground
    Wetedge Satin Matrix Interior (Pebble)
    Paramount In-floor System
    Pentair IntelliFlo VS 3050, Pentair Triton II TR100 Sand Filter
    Pentair Intellichlor IC40 SWG
    38,281
    Re: Pool has no weir
    The weir helps the surface skimming tremendously and prevents the dirt floating back out when the pump turns off.
    You can either try to find the one designed for your skimmer that may screw in, or get one of the universal spring-loaded ones.
    Modawg2k's Avatar
    May 2013
    Phoenix, AZ
    334
    Thanks. I definitely need one. I can see all the junk that comes out when the pump isn't on
    Modawg2k's Avatar
    May 2013
    Phoenix, AZ
    334
    Looks my skimmer is a Pentair..... according to the skimmer lid. Here's how my skimmer looks now. My contractor abandoned the job so I've been left to sort out the missing items. You can see the area just looks incomplete. I see areas for a weir to latch into, so I will look into pentair to get one. It looks like all I would need is the weir and it should snap right in, correct? Does it look like I may be needing anything else for this area?
