Results 1 to 8 of 8
Thread: AGP Pump question
    May 2013
    Tulsa, OK
    83
    AGP Pump question
    My local store has a Jacuzzi Filter and Pump System that is coming with the Doughboy pool we are installing. It is a 1 1.5 Hp Self Priming W/ Run Dry feature Single speed. Its also coming with a Jacuzzi 300lb sand Filter.
    The pump they said is made for inground application. Is this an issue? Im still studying the chemical ABC's and dont want to miss anything with my Pump and Filter kit...
    They had some other options but this is what comes with it. They say it is the best that they offer. Just making sure this isnt a bunch of smoke being blown.
    12x24 Doughboy. 8700 gallons~ 2 HP Dyanmo Pump~ 26" Sand Dollar Filter~TF 100 test kit~ Zodiac Ranger AGP automatic cleaner.
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,556
    Re: AGP Pump question
    What size/how many gallons of pool are we talking about?
    May 2013
    Tulsa, OK
    83
    Sorry, 12x24. Think it figures 8500 gallons.
    Apr 2010
    East Texas
    9,556
    That's plenty big enough sand filter. Pump HP is overkill...........I have a 1.5 on my 16x32 and it's way too much. Someone will be along to answer the above/inground pump part for you.
    mas985's Avatar
    Pleasanton, CA
    11,737
    Usually IG pumps are "bigger" than the equivalent HP AG pumps so given the size of the pump, it could be over sized for the filter. Is the pump paired with the filter as a combo unit? Can you post the part#s for the pump and filter?
    Mark
    May 2013
    Tulsa, OK
    83
    They have them paired as a set but don't know if they truely are a set. Let me obtain specific part nunbers to see that helps. He did tell me this is the set up they run on the majority of their IG installs.
    May 2013
    Tulsa, OK
    83
    Now I do recall a pentair SD 60. 1.5 Hp single speed pump paired with a pentair 250lb sand filter. That was also available at same price.
    mas985's Avatar
    Pleasanton, CA
    11,737
    The Pentair combo would be a better system. It uses the Dynamo pump which is a good pump. Also, the 1.5 HP pump that comes with the combo is SPL rated which is the same as the 1 HP up rated Dynamo (just marketing). So it actually isn't all that big of a pump. It fits nicely with that filter and is more than enough for your pool. They make a two speed version that would be a better choice and allow you to run on low speed most of the time.
    PNSD0060DO2260 or PNSD0060DP2160
    Identical systems but the 2260 is labeled as 1 HP while the 2160 is labeled as 1.5 HP. The pumps are actually identical, just the labels are different.
    Mark
