- May 21, 2013
- 1
I am a new member and registered because I have information on SWG causing cloudy water from jets. I have an Aqualine Goldwater SWG. T-cell 15. Inground/vinyl pool/36k gallons. I had the circuit board replaced bc it's still under warranty. That's a different problem with a simple solution I found on another thread if your warranty is expired. Anyway... When it's generating I get the milky white water coming out of the jets. I don't have leaks. It only does it when the SWG is turned on (auto or super chlorinate). I have been researching this issue for a few days. I added the SALT opening chemicals when I opened it bc I didn't know the SWG wasn't working. Then I added tons of shock, chlorine, NON foaming alg, and a clarifier and was treating it as a reg pool until the SWG was fixed. It had been clearing up pretty good until the SWG was repaired. As soon as I turned it on- milky water out of jets and foamed up the pool. It looked like a bubble bath! I've been dealing with this for a week. It HAS dissipated some but still happening. My chem levels are all within normal range and salt is 3400 ppm. I just hung up with Hayward tech support for Aquarite Goldline SWG- (908) 355-7995. I had a nice guy that never heard of it. He put me on hold for 15 minutes. He spoke with the chemical engineer (so he said) and the ANSWER was: The chlorine produced from the cell is reacting with something I put in the pool. Algicide? Clarifier? Bags of shock? Who knows? Anyway... He said to let it run for a few days and it should take care of itself. I drained a few inches and am putting in freshwater. I will probably do this a few times. I will let you know my results!!
