Thread: Opened pool this afternoon...
    pepsiholic's Avatar
    May 2009
    Fairmont, WV
    362
    Water is crystal clear, very little debris, just mostly dirt on bottom. I am adding about 4-5 inches of water to get the pump started. As soon as I got the cover off, it started to downpour and we're under severe storm watches until late tonight...Just my luck..haha.
    Happy Pool Season!
    Here are my opening numbers:
    Ph 7.2
    TA 70
    FC 1
    CC 1
    TC 2
    CYA not really sure, it's reading about 50, but is very cloudy out, so my best guess is probably between 30-40.
    So my question, I guess is, when I begin the shock process after the pool fills up, should I go ahead and shock at a level of 30 or so? And then wait for some sun to get a more accurate reading? And will the TA rise on it's own one the PH balances out, after shocking?
    This site is the best and never fails to get me up and going within a day or two!
    24 x 52 Round AG Outback Empire Pool 13,500 gal.
    1 HP Hayward Power-Flo pump w/Hayward 18" 150lb. sand filter
    TF-100 test kit & SpeedStir
    Wanda the Whale Vacuum
    30,432
    Re: Opened pool this afternoon...
    It seems to me I get slightly higher readings when I go outside, back to the sun, for the CYA test.
    So you might be 60 ppm CYA or so. If the sun doesn't come out, take what you have now....50 ppm.
    Leave your TA alone until everything else is where you want it.
