Thread: bleach and solar cover
    pakrh8r's Avatar
    May 2013
    Chicago, Illinois
    43
    I will be trying the BBB method (currently using trichlor pucks) and want to know if I should remove my solar coverfrom my AGP , as opposed to just rolling it back a bit, before adding bleach in front of the return. If I do, how long should I keep it off before putting it back on? My goal is to keep the new solar cover at least a full 2 seasons. My first cover started shedding all of its bubbles during the middle of the 2nd season and was shredding by the end. Thanks.
    5500 gal. Plastimayd & Vynall AG (12' x 18' oval), Hayward Swimpro Voyager Cartridge filter & pump, Hayward H150 heater
    TF 100 Test Kit, converted to BBB in 2013
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Re: bleach and solar cover
    I just flip back the cover so that I can access the return flow and put my chems in there. Then I flip the cover back over the water. With an appropriate amount of FC for your cya level and proper ph balance, your cover should be fine. Most solar covers do not last more than a couple years regardless.
    pakrh8r's Avatar
    May 2013
    Chicago, Illinois
    43
    Sounds good, thanks.
    Quote Originally Posted by linen
    Same here -- no problems.
    Aaron
    [ Vogue Vectra 24' AG | Hard plumb: Hayward Power-Flo Matrix 1HP 2-speed, 27" sand filter & Pentair MiniMax 100 NG | Taylor K-2006 | Central IL ]
    Powered by: TFP, PoolMath & TFTestkits
    Smykowski's Avatar
    Sep 2011
    3,065
    The only reason to take the cover off is to allow the pool to "breathe" during shocking. All you're doing is allowing the process to offgas the nitrogen from the reactions. If your pool is clean to start with, there are no chloramines to break down, and no nitrogen gas to get rid of. As for structural damage, the bleach is no more damaging to the cover than to a liner. I plan on leaving my solar cover on for the vast majority of the time this summer.
    pakrh8r's Avatar
    May 2013
    Chicago, Illinois
    43
    Thanks for the info everyone. It looks like I'll just roll it back a bit unless I'm shocking. Thanks.
