suds on water surface when splashing
Jun 30, 2010
1
I was preparing my pool for opening and added a cheap algeacide from Walmart (won't do this again). I only added the amount recommended on the bottle (12 oz). My water is crystal clear and all the chemistry numbers are good except CYA which I still need to raise. However, after adding the algeacide small suds appear on the water surface when it is splashed (we have a water feature). I have seen in other posts that the cheap algeacide is most likely the culprit and there is basically nothing you can do but wait for it to go away. My question is, is it safe to swim in now or should we wait for the suds issue to go away?
30K Gallon Gunite Pool
TC 3.0
PH 7.6
TA 120
CH 400
CYA < 20 (need to raise this)
JD
