Thread: Cracked pipe
    tcat's Avatar
    May 2012
    Austin, TX
    731
    Cracked pipe
    See the "clear" pipe to the left of my multi-port valve? I went to drain some water the other day and water spewed out of a crack in it. Odd they would insert a viewing port there, what are you looking at besides water flowing? It's turned so yellow/orange with age you can't see though it anyway. Any good external cements to patch something like this? Can't really replace it without replacing whole valve. Not a real big deal until it breaks.. just want to prevent that.
    IG pebble, 15,000 gallon
    48” PentAir DE Filter with backwash valve
    PentAir Whisperflo pump with 1hp 2-speed motor
    Aquabot 4WD, Poolskim
    Intermatic Dual Timeclock with freezeguard
    DIY chlorine feed
    BBB
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,000
    Re: Cracked pipe
    Quote Originally Posted by tcat
    That's supposed to be a view window - some call it a sight glass - to watch the waste water when you're backwashing so you know when it's clear.
    Even when backwashing or draining to waste there shouldn't really be any significant pressure on it if it just dumps into the sewer or spews out on the ground somewhere. A hunk of rubber hose and some hose clamps will fix it if it breaks.
    22,549
    Re: Cracked pipe
    As Richard said, the only time it'll see any water is when you're backwashing so I wouldn't worry about it unless it's making a real mess. You can just wrap it with some rubber or tape if it's very bad. Another thing it's good for is telling if your multiport is leaking water out the waste port when not backwashing.
