Results 1 to 13 of 13
Thread: Wiring/Breaker Size for Sub-Panel
    Hello.
    I'm soon to have our new 14x28 in ground vinyl lined pool installed.
    A shed aprox 8 feet from the pools edge will be installed hosting a sub-panel. I will be doing the wiring myself. Shed is ~40 from the house.
    My question is regarding wire size and breaker sizing; Im reading mixed things around the wonder WWW.
    What Im planning: adding 60 AMP double to my existing panel in the house. Running 6-3 PVC Jacket - 600 Volt PVC/Nylon Insulation - 90C UL Type TC - with Ground ER Rated Tray Cable to the shed. In the shed will be a 100 AMP rated sub-panel. Equipment is a 95,000 BTU electric heat pump, 1HP pool pump, 2 LED pool lights, and salt chlorinator.
    In the sub-panel is a 40 AMP double for the heater and 15 AMP double for the pump and 15 AMP single for the salt and pool lights okay? Would this over load the 60 Amp in the house panel, I was assuming no as not everything is running a full draw.
    Also any advise on a GFI within this mix and any grounding plates if you please.
    Thanks in advance.
    22,553
    Re: Wiring/Breaker Size for Sub-Panel
    The 6/3 will be fine, but I think I'd go ahead and run #4 if you think you'll ever add any more stuff to it.
    You'll either need for one of the main breakers to be GFI or each of the individual breakers to be. I'd go with the individual breakers as if one trips it won't shut down the whole panel.
    24' x 52" Round AGP. 2hp/hp SPL Power-Flo 2-speed pump. 200sqft Waterway Cartridge Filter. 45MHP2(3GPD) Stenner Peristaltic Pump
    Dec 2009
    Central Massachusetts
    2,690
    If it were me, I'd put a 100 amp breaker in the main and run that out there instead of 60 amp. You;ll need bigger wire, but in the long run you wont be limited on power.
    Not sure on the wire either. The ground wire feeding a subpanel for a pool needs to be insulated. Not sure what you described has an insulated ground.
    14,000 gallon IG, Vinyl. Hayward 3/4 hp superpump, Penatair IC40 SWCG, Pentair automation, Hayward sand filter, Aqua Comfort heat pump, Hayward 400k Lo-Nox LP heater.
    There is limit to how many amps to put thru a 6/3 and or 4/3.
    On 6/3 it is 70 amps and that more than enough for any pool and or spa combo, don's add up the circuit breakers and think you need that size main, just look at you main house panel most always add up to more than the sum of the breakers, because you never draw power to all at the same time.
    I would use a 6/3 with a 70amp in the main service panel to the sub,
    just did it and was approved with UL cert.
    Thanks for the feedback so far, always helpful.
    One thing I should mention is that my current home panel is only 100AMP service. With putting in a 60AMP double to my sub-panel (or a 70AMP double) am I asking for trouble or does this fall under the "not everything runs at full draw and at the same time".
    Thanks!
    correct to my understanding ""not everything runs at full draw and at the same time""
    gtemkin's Avatar
    Jun 2008
    Seattle, WA
    738
    Quote Originally Posted by Nova13
    Nova13, just wondered what you meant by "approved with UL cert". I've heard of using UL listed electrical components but I haven't heard of getting a UL cert approval on a wiring job. Does this mean your local authority approved your work. Thanks.
    21K gal 16' x 40' in-ground pool built 1959, old school with Jacuzzi bronze pump, American Products 24" Sand Filter & Americana Multiport valve, Jandy Lite2 millivolt heater, Coverstar cover, and classic Kreepy Krauly.
    Dec 2009
    2,690
    UL cert is one thing, the NEC is another. And the NEC says ground wires for pool wiring whether to a subpanel or the pool equipment itself require an insulated ground.
    Quote Originally Posted by gtemkin
    Yes, part of the building permit included a underwriter stop by an then issue a cert, It will be forwarded to my insurance Co.
    gtemkin's Avatar
    Jun 2008
    Seattle, WA
    738
    I think the underwriter who visited and the certificate issued relates to your mortgage and home insurance but not UL, which is a trademarked designation and stands for Underwriters Laboratories, a non-profit organization that issues safety standards and performs tests on manufacturer's products among many other things. In other words, someone who has the occupation of underwriter doesn't necessarily have any association with UL; and a certificate from an underwriter is very much different than a certificate from UL.
    Here they call it an UL Cert, I own my house, no mortgage.
    It's a certificate that basically says the wiring meets the building code, not sure Y U R splitting hairs?
    Dec 2009
    2,690
    Out of curiosity, where are you from?
    Normally an electrician pulls a permit and the work is inspected by the local electrical inspector. I dont think anybody is splitting hair, its just that nobody has heard of a UL cert like this.
    Did it in NY & now FL, I don't use an electrician, as a home owner U can do your own work and get it.
