Thread: Question about Sodium Bisulfate 93.2%
    Jul 2010
    Mickleton, NJ
    229
    I couldn't find MA at Lowes today so I grabbed PH Down which is Sodium Bisulfate. I've never had to lower my PH, it is at 7.8 right now. Usually I start the season off a little low and with areation and the kids splashing around it is up to where I want it in no time. According to the label I should use 7 oz per 12,500 gallons which is about what my pool is to get it from 7.8 to 7.6. Is this ok to use or should I take it back and find MA. I don't anticipate it's something I'll need regularly. For the past two seasons I've only needed bleach the entire time. I replaced a lot of water this year though and did need to add CYA to get me from 20 to 30 so I wasn't sure if this had anything to do with it.
    Currently Pooless
    Former Pool:Buster Crabbe resin and steel 30'x15' oval 52" ABG pool Pentair sand dollar filter 1.5 Pentair Dynamo pump13,500 gallons
    30,414
    Re: Question about Sodium Bisulfate 93.2%
    MA is usually noticeably cheaper and does a somewhat neater (chemically) job.
    7.8 is still in the safe range so I would return it on the next trip.
    Muriatic Acid is in the paint section at the several Lowe's that I go to.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,984
    It's out in the garden department wher I am.
