Thread: Aqua Rite Replacement Cell
    cws91's Avatar
    Nov 2009
    Baton Rouge, LA
    15
    I'm looking to replace the cell for my Aqua Rite generator system.
    Based on my pool size (21,000 gal) I figured I would need Hayward's T-Cell-9 (under 25k gal).
    When shopping sites, one noted that if my system was older than 2009 I could only use a T-Cell-15. I bought the house in 2009 with the existing system so it was installed prior to 2009.
    Is this correct?
    BTW my problem I'm experiencing that has me looking into replacing the cell is that the controller has a constant reading for salt of 2000 when I know my salt level is at least 2800-3000.
    Any thoughts on a fix? Thanks
    21,000 gallons
    Pentair 420 Clean & Clear Plus Cartridge Filter - Filter Area: 420 - Design Flow: 150
    Inground Plaster
    Pentair Whisper Flo Pump - 1 HP - Model CCP420
    Pentair MiniMax NT Series Pool Heater
    Aqua Rite Electronic Chlorine Generator
    Polaris 280 Cleaning System
    38,475
    Re: Aqua Rite Replacement Cell
    Actually we recommend sizing the cell 1.5-3X larger than your pool. So I would definitely get the T-15, even if your system was capable of using the smaller cells.
    Have you cleaned the cell? Have you had it checked at a pool store to see if it is bad?
    cws91's Avatar
    Nov 2009
    Baton Rouge, LA
    15
    Yes I cleaned it and made sure of my salt level but still no change.
    Having the cell tested was my next step. I was just starting to get prices on replacements to see what the damage may be.
    Thanks
    21,000 gallons
    Inground Plaster
    38,475
    There was a thread last week about a company that is selling "refurb" cells with warranties for around $300 I think. Supposedly the plates are a higher quality that should last longer.
    See 2nd half of this thread:
    cell-life-t36676.html
    cws91's Avatar
    Nov 2009
    Baton Rouge, LA
    15
    Thanks I'll give that a try.
    21,000 gallons
    Inground Plaster
