Thread: Still cloudy...
    Still cloudy...
    Help please! My pool is still cloudy after several bags of shock and liquid chlorine. I had my water tested professionally yesterday and cya was in check and ph was fine. I was told to add 2 more bags of shock and conditioner and let pump run over night. Still reading between 2 and 4 in chlorine and ph is fine but water is very cloudy this morning. Any suggestions?
    Kim...new pool owner with no owners manuals :)
    18ft above ground doughboy pool with power pak ii pump and sand filter approx. 20,000 gal
    Re: Still cloudy...
    Youe chlorine levels are not at shock level. You must raise it to shock level and keep it there by testing and adding chlorine as needed to maintain shock level. You do this until your water is clear. Run your filter 24/7 until clear. Your now going to be told in following posts to read pool school, buy a good test kit, and that the pool store is stupid (it is)
    11,250 gallon in-ground plaster pool, Hayward/GoldLine AquaLogic AQL-PS-8 control panel, Hayward TriStar 1 HP pump, Hayward SwimClear cartridge filter (324 Sf), Hayward Turbo Cell T-Cell 15 SWG, Navigator Robotic Cleaner, TF-100 Test Kit
    Butterfly's Avatar
    South Carolina
    10,045
    Re: Still cloudy...
    Well, I suggest you order one of the recommended test kits so that you can have a professional test, done by YOU!
    The fav around here is the TF100. Link in my sig.
    "in check and fine" don't mean anything to us. We need test results from a good test kit.
    So, two things: First order a test kit and second, start reading Pool School!
    Once we get a set of test results, we can help you
    You're done SLAMing when:
