Thread: Help with cya
    Help with cya
    Hello all. I am new to the bbc method and had a few questions. I bought a taylor k2006 kit. my ph 7.4, FC-9, ta-90, and cya is reading 90. I just opened my pool last week. The only chemical I added after opening is two bags of dichlor shock. I was confused on how to test the cya. I am supposed to keep adding the cloudy solution until the dot completely disappears, or just barely disappears? This test is tricky for me because I sometimes can not see the dot and then it will appear again in seconds. I do not know why I would have such a high cya level if I have not added any conditioner. Could my cya level be falsely reading because I just shocked my pool with dichlor? I would not expect shocking 1 time would bring my cya that high. I filled about 3/4 of my pool with fresh water this year. Could I be getting a false reading because my cya is zero? any tips on reading the cya test with the taylor kit? Thanks Jeremy
    15000gallonVinylAG, sand filter, built in 2007
    30,426
    Re: Help with cya
    Hi, Jeremy, Welcome to the forum.
    I can't fully explain why your CYA is high, although I hate dichlor....it is troublesome to use for shock.
    What I can help with is your CYA is certainly high....perhaps not that high, though. Reread the directions on how to perfdorm the test and then try the test over and over from the same sample (pour it back and forth) and then take the avberage of what you see.....that'll be close.
    You'll get very good at that test in time.
    What does your water look like?
    Re: Help with cya
    water is clear. I was confused on when testing: Does the dot need to completely disappear, or barely disappear? Is is possible to get false high cya readings if I resonantly shocked my pool? Thanks again, Jeremy
    Jun 2012
    Louisville, KY
    266
    Re: Help with cya
    As long as the dichlor is thoroughly mixed it won't interfere with your cya test.
    Dot should barely disappear when viewed at waist level with your back to sunlight.
    18x36 inground vinyl lined, Hayward sand filter and tablet chrolinator, approx 18k gallon
