Thread: Stop/Resume button on Hayward variable speed pump
    Issue: When I have one of the Speed buttons pushed on the Hayward variable speed pump, then push the Stop/Resume button the pumps stops. However, when I the push the Stop/Resume button again the pump does not start back up. Have I messed something up or does the Stop/Resume button not work when one of the four speed buttons has been pushed? I see no error message of any sort, everything appears normal however the pump does not come back on.
    Rick
    Re: Stop/Resume button on Hayward variable speed pump
    Normal operation. What you are doing is stopping the speed setting you manually entered and when pressing resume it will resume normal pre programmed timer operation. If you want the speed again just hit the speed button.
    pool size - 40kgal
    finish - Gunite
    pump size in horsepower and brand-Variable Speed, Hayward EcoStar SVRS3400
    filter size - Sta-Rite S8M150
    additional equipment - Hayward CL220 Chlorinator
    Thank you much! So if I understand you clearly, the stop/resume button essentially doesn't work when utilizing the pre-set speed options. The button only works when the pump is operating under "normal operation" or when the programmed daily running of the pump is occurring, is that correct? I am wanting to do a backwash of the pool is the whole reason this issue occurred. I guess I just have to manually push the speed and stop buttons each time I move from filter to backwash. I just find it odd that when doing this the pump will have to prime each time for three minutes unless there is an easier way I am unaware of...any tips would be appreciated!
    Rick
