Thread: First time testing my pool EVER!!
    New 24ft pool put in at the end of last season. Added 5 gallons of bleach and covered it up for the winter (Upstate NY). Did some research over the winter and ordered the Taylor K-2006C kit. pulled the cover off and started running the pump.
    Here are my results.
    14,400 gallons
    65%
    FC 0
    CC 0
    PH 7.6
    TA 100
    CYA 0....is this possible?
    So based on the calculator I added 2 gallons of 6% bleach. Am I on the right track?
    Thanks
    linen's Avatar
    Jul 2010
    Twin Cities, MN
    8,649
    Re: First time testing my pool EVER!!
    Welcome to tfp, BuffaloMark
    Quote Originally Posted by BuffaloMark
    14,400 gallons
    I get 12500 assuming 54" wall but really only 48" depth.
    65%
    What is this?
    Yes, since you did not put any in (I am assuming) and it would not be in fill water.
    If you water is clear, then I get 57 oz of 6% bleach to get to 3 ppm FC (assuming 0 cya) from poolcalculator.com.
    You should start getting some cya in the pool. Shoot for 30 ppm cya to start. Put it in an old sock and place it in front of the return.
    Quote Originally Posted by linen
    Sorry, I'm still learning !
    14,400 gallons
    You are correct, I calculated it myself using 54 inches not the correct 48"
    65%
    What is this?
    65 is the Degrees of the water.
    Mark
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Mark - I've always used 13,500 as my gallonage and my dosages have been spot on for the most part.
