Thread: Help evaluate bid 1:Fiberglass pool in austin texas
    May 2013
    austin/texas
    140
    I am updating the quote below after talking again with the PB for a Leisure pool
    Leisure Moroccan 34, in-ground Fiberglass, Saltwater
    Size: 34'2" x 15" (5' 11" deep end)
    Depth: 3.5 to 6 feet
    Area: 462 sq. ft.
    Volume: 17,100 gallons
    Pool plumbing 2" schedule 40 PVC
    Pump: pentair SuperFlo 1.5HP, 2-speed
    Filter: pentair clean & clear 350 cartridge
    Chlorinator: in-line chlorine feeder
    Lights: Color LED 12v with wireless remote
    Suctions: dual main drains and skimmer
    Cleaner: includes free pre-plumbing for extra booster pump for cleaner. (I wil purchase later online either a booster pump and legend II or a robotic cleaner, budgeting $1000 total)Returns: 4
    Equipment pad, extension pole, leaf net, hand vacumm with hose, start up, test kit
    complete start to swim installation with permits, 3 ft concrete deck, equipment
    crane
    97 sf of structural bond beam
    base price: $40,300
    upgrades:
    $1880: pentair intellichlor p-4 salt system with control panel
    grand total price with upgrade: $42,180
    payment will be %5 deposit with contract, 40% before excavation, 40% up pool arrival, 15% final payment
    Not included:
    Rock excavacation for up to 4 hours, total $600, if needed.
    What do you think about the setup and pricing? Should I just do the pre-plumbing for the automatic cleaner and then I buy a pentair/polaris, or should I skip all together and do a robot cleaner?
    Also not sure about the heat pump since winter's are not long or harsh in central texas?
    thanks for all your help, this site has been awesome so far and extremely educational.
    34x15, 17K Fiberglass In-Ground Leisure Morroccan SWG, 1 1/2HP 2 speed SuperfFlo pump, Pentair Intellichlor SWG, Pentair Clean & Clear 320 cartridge filter, Pentair EasyTouch 8 panel, 4 returns, 1 skimmer, Installed August 2013, Fiberstar 3-color LEDs, AquaBot AWD robot cleaner, Pentair Easy Touch 8 Wireless remote.
    Killer95Stang's Avatar
    Sunny SoCal
    591
    Re: Quote for FB in austin texas, thoughts?
    See if you can negotiate the final payment to something like 10%. At 5% at completion, what is his incentive to finish?... $2500?
    I'm not too familiar with Austin Texas and prices of Inground gunite Pools... but at nearly $50K.. why fiberglass? (If I'm correct you are getting fiberglass?)
    Pool done!! (backyard = work in progress) 32' x 19' inground freeform with 7' spa, baja step w/ (2) bubblers, stonescapes mini pebble finish, rock waterfall feature, 12" raised bond beam, Intelliflo VS, Whisperflo feature pump, (3) 5G Color LED's, FNS + DE 60, 400K Master Temp, Easytouch 8 w/ remote, Intellichlor IC40, Vision Classic Ceramic Kamado smoker, Margaritaville DM1000!!! Party Coming Soon!!
    TF-100 Test Kit w/ Speedstir
    May 2013
    austin/texas
    140
    good point on the final payment, will check on that. from all my research fiberglass seems to be the easiest to maintain and less costly in the long run. I also look at price being $38,000 since I would have to pay for the same upgrades if I did gunite.
    Re: Quote for fiberglass in austin texas, thoughts?
    sounds about 10K too much.
