Thread: I couldnt get pressure so i filled my pump basket ...
    Hi Again, I couldnt get pressure so i filled my pump basket and turned on the pump and it worked, ran it for 2 days, vacuumed, then backwashed, turned off the pump and now when I turn it on, no pressure again. It wont filter. tried filling the pump basket again and it still wont work. I have a Large hayword series filter 50 psi with a a.o.smith 1.5 hp pump.. is it the size of the pump?????
    Re: Pool Openings
    vacuumed a lot of worms could they have clogged the pipe
    30,419
    Re: I couldnt get pressure so i filled my pump basket ...
    With the pump running, are there bubbles in the pump strainer basket or just air?
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,995
    Quote Originally Posted by markburley
    That 50 PSI just jumped out at me. Is that the pressure it was running at, or did you get that off the label?
    Also, does the gauge work? Or did it, when it was pumping? What does it say when its off, and did you see what it was running at when it did work?
    Not priming means either no water or the impeller isn't spinning. Since it went dry before but worked when you manually filled the basket, I'd start by looking for an air leak on the suction side. Round up the usual suspects: low water level, stuck weir in the skimmer, loose drain plugs on the
    pump, poor seal on the pump strainer basket, and leaks at the fittings, especially any couplings.
    [center:qi3xpux1][youtube:qi3xpux1]vtSmfws0_To[/youtube:qi3xpux1][/center:qi3xpux1]
